Gabe
BenQ MH560 Projector, with 3800 ANSI lumens and 1080P resolution. Let's see if this is a good projector.
The appearance of BenQ still uses the old traditional projector design, the overall design is pure white, the overall size is moderate, the three circumferences are 296mm long/221mm wide/120mm high.
The lens is an all-glass lens, light transmission and heat resistance are better than resin lenses, better imaging, and will not run out of focus due to long standby time and lens overheating.
The brightness of the screen reaches 3800 ANSI lumens, and the contrast ratio reaches 20000:1. Here are the actual pictures to get a real feel of BenQ MH560's picture performance ability.
1. Appearance
2. Specs
Model Name | BenQ MH560 |
Brightness (ANSI lumens) | 3800 |
Native Resolution | 1080P (1920x1080) |
Native Aspect Ratio | 0.672916667 |
Contrast Ratio | 20000:1 |
Light Source | Lamp |
Throw Ratio | 1.49~1.64 |
I/O Interface | PC in (D-sub 15pin) (x1) Monitor out (D-sub 15pin) (x1) Composite Video in (RCA) (x1) S-Video in (Mini DIN 4pin) (x1) HDMI in (x2),HDMI-1 (1.4a/HDCP1.4),HDMI-2 (1.4a/HDCP1.4) USB Type A (x1) USB Type Mini B (x1) RS232 in (DB-9pin) (x1) |
Speaker | (x1),10W |
Acoustic Noise (Typ./Eco.)(dB) | 34/29 |
Dimensions (WxHxD) (mm) | 296 x120 x221 |
Net Weight (kg) | 2.3 |
3. Picture quality
