Mia
Partial sun is the single most common mounting environment for outdoor TVs in North America, and it is also the environment where picking the right television gets surprisingly tricky. Your spot is not a fully covered porch where a low-brightness shade model would do fine, but it is also not an exposed poolside deck that demands a $3,000 full-sun flagship. It is somewhere in between — a pergola with slatted shade, a covered patio with afternoon overhang, a screened porch that catches reflected light from a pool, a deck with western sun that peaks for a few hours a day. The right TV for this environment needs roughly 1,000 to 1,500 nits of brightness, a proper anti-reflection screen coating, purpose-built weatherproofing rated at least IP55, and build quality that can handle temperature swings and occasional rain without needing a separate weatherproof enclosure. Overspec it and you are paying for nits you will never see. Underspec it and you end up with a washed-out screen by 2 PM on a summer afternoon. After working through the current partial-sun market, these are the five 55-inch outdoor TVs we think deserve a close look in 2026, each with its own distinct case for the right kind of buyer.
SunBriteTV has been building purpose-built outdoor televisions longer than nearly anyone in the North American market, and the Veranda 3 Series 55-inch at roughly $1,799 is the brand's flagship partial-sun option and the model most custom AV installers default to when they are spec'ing a residential patio. What you are really buying with the Veranda 3 is the ecosystem around the TV as much as the TV itself. SunBrite has built the deepest installer and dealer network in the category over more than a decade, which means warranty claims, replacement parts, and service calls are handled through channels that simply do not exist for newer entrants to the category. The hardware itself is legitimately capable: a 4K panel running at 1,000 nits of brightness with a well-calibrated anti-glare screen coating, IP55 weatherproofing on an all-metal chassis, Android TV for streaming app support, and an operating temperature range that covers most North American climates without requiring an enclosure. The trade-offs at this price point are that brightness sits at the lower end of the partial-sun spectrum, meaning it performs best in the more heavily shaded end of partial-sun installs rather than spots that catch direct afternoon sun, and HDR support is limited to HDR10 without Dolby Vision. For buyers working with a SunBrite-affiliated installer or those who place a premium on brand heritage and the warranty infrastructure that comes with it, the Veranda 3 is a legitimate anchor choice in the partial-sun category.
The ByteFree Outdoor TV at $1,499 stands out in the partial-sun category for a specific reason: it delivers the highest rated brightness in this comparison at 1,500 nits, which lands at the top of the partial-sun range and makes it noticeably more forgiving in mount locations that see more direct light than a traditional partial-sun install. That extra brightness headroom matters if your pergola has widely spaced slats, if your covered patio has an open western exposure, or if your screened porch sits next to a pool that reflects daylight back onto the screen. Beyond brightness, the ByteFree is the only TV in this roundup that ships with full Dolby Vision HDR support — the dynamic HDR format used by Netflix, Disney+, Apple TV+, Max, and Amazon Prime Video for premium streaming content — paired with Dolby Atmos on the audio side and 15W × 2 built-in speakers. The connectivity configuration is the most complete in this group as well: two HDMI 2.0 inputs plus one HDMI 2.1 with eARC for future-proof source device support, two USB 2.0 ports, an Ethernet port, a fiber optic audio output, and a dedicated AV-IN jack for legacy equipment like older security DVRs or first-generation consoles. The build matches the category standard with an all-metal chassis and IP55 weatherproofing running 4K at 60Hz on a real Google TV operating system without proprietary skins. The one honest constraint worth flagging is the operating temperature range of 32°F to 122°F (storage extends to -4°F), which is narrower than some competitors and makes it less suitable for buyers in genuinely cold climates who plan to leave the TV mounted outside through northern winters without a cover or enclosure. For most North American partial-sun installations used from April through October, that temperature window covers the actual conditions, and at $1,499 it is also the lowest sticker price on this list.
The Sylvox DeckPro 3.0+ 55-inch at roughly $1,699 is the newest entry in Sylvox's half-sun lineup and the model designed to directly compete with the SunBriteTV Veranda and other established partial-sun options. What makes the DeckPro 3.0+ distinctive in this comparison is two specific build-quality advantages that matter for installations in harsher environments. First, it carries an IP56 weatherproof rating rather than the IP55 found on the other four TVs in this roundup — a step up in water jet protection that matters primarily if your mount spot gets pressure-washed regularly or sits somewhere with significant direct water exposure like a poolside cabana. Second, its operating temperature range extends from -22°F to 122°F, giving it the widest cold-weather envelope in this group and making it the most defensible pick for buyers in northern climates like the upper Midwest, northern New England, or the Canadian provinces where the TV might stay mounted outside through winter. The 4K panel runs at 1,000 nits of brightness — solid for the more heavily shaded end of partial-sun installs but not the strongest option if your location sees meaningful direct light — and the software runs on Google TV with Dolby Atmos audio. HDR support tops out at HDR10, without Dolby Vision. Speaker output is also slightly stepped down at 12W × 2, noticeable if you rely on built-in audio rather than a soundbar. For buyers whose primary concern is cold-climate durability and the highest weatherproofing rating available at this price point, the DeckPro 3.0+ is a legitimate pick.
Furrion built its reputation on ruggedized displays for the recreational vehicle and marine markets before expanding into residential outdoor, and the Furrion Aurora Partial Sun 55-inch at roughly $1,699 carries that heritage into a residential product that sets itself apart through a specific set of engineering priorities. The chassis construction is notably more vibration-resistant than purely residential-focused outdoor TVs, which matters if your mounting surface experiences movement — think a deck floor that flexes, a pergola that sways in wind, or a wall shared with a high-traffic household area. The weatherproofing is IP54 rated, which is slightly below the IP55 on the other TVs in this roundup but still comfortably above the threshold for protection against rain, dust, and typical outdoor exposure. Brightness lands at 400 nits for direct comparison purposes — lower than the ByteFree and Sylvox options — but Furrion's proprietary Climate Smart technology continuously adjusts picture output based on ambient temperature and lighting conditions, which helps real-world viewability in changing environments even if the headline nit figure looks modest on paper. The 4K panel is paired with Furrion's proprietary smart TV platform, which is simpler than Google TV and may require an external streaming stick for the best Netflix, Max, or Disney+ experience. For buyers who want genuine multi-environment durability — part-time RV use, a lake house that transitions between indoor and outdoor storage, a setup that needs to survive both residential patio use and occasional transport — the Furrion's engineering pedigree is a distinct advantage.
Peerless-AV is primarily known as a commercial AV brand, and the Neptune Partial Sun 55-inch at roughly $1,499 reflects that heritage directly: this is a television engineered first for bar, restaurant, hospitality, and multi-unit residential amenity use, brought into the residential market at a competitive price. The commercial orientation brings specific advantages. The chassis is built to handle longer continuous service hours than consumer-grade outdoor TVs, the warranty terms are oriented toward higher-use installations, and the mounting hardware options and installer documentation are more extensive than any other brand in this comparison — which matters if you are spec'ing the TV for a rental property, a vacation home that sees variable traffic, or any location where service downtime costs money. The 4K 60Hz panel carries a partial-sun brightness rating with IP55 weatherproofing and an all-metal construction that feels noticeably heavier and more industrial than consumer-grade alternatives. What you give up at this price is smart TV polish: Peerless outdoor TVs typically run a simpler proprietary interface that is functional but substantially less refined than Google TV or Android TV, and many streaming apps — including Netflix, Max, and Disney+ — work best through an external streaming stick rather than the built-in platform. For residential buyers who want the longest-running hardware and the strongest commercial-grade build at this price point and who are comfortable adding a $40 streaming stick to handle app playback, the Peerless Neptune earns serious consideration.
All five of these televisions are legitimate answers to the "best outdoor TV for partial sun" question, but the right answer depends on your specific install environment and priorities. If your mount location sees the brighter end of partial-sun exposure — wide-slat pergola, open western deck, reflective pool environment — the 1,500-nit brightness on the ByteFree handles that headroom better than the 1,000-nit options. If your install is in a genuinely cold northern climate and the TV stays outside through winter, the Sylvox DeckPro 3.0+ or Furrion Aurora are better matched to your temperature envelope. If you are working with an established AV installer or value the longest warranty track record in the category, the SunBriteTV Veranda 3 brings brand infrastructure the newer entrants cannot match. If the install is at a commercial property, rental, or high-traffic amenity space, the Peerless-AV Neptune brings the commercial-grade engineering that environment demands. The category rewards matching the TV to the environment rather than chasing the highest-rated spec sheet, and in the partial-sun tier specifically, all five of these options are delivering real value at different points on the priority spectrum.
1. SunBriteTV Veranda 3 Series (55")
2. ByteFree Outdoor TV (55")
3. Sylvox DeckPro 3.0+ (55")
4. Furrion Aurora Partial Sun (55")
5. Peerless-AV Neptune Partial Sun (55")
Choosing the Right Partial-Sun Outdoor TV for Your Patio
Quick Reference: Best Partial-Sun Outdoor TVs of 2026
| Model | Price | Brightness | HDR | Weatherproof | Operating Temp | OS | Distinctive Advantage |
| SunBriteTV Veranda 3 | ~$1,799 | 1,000 nits | HDR10 | IP55 | Wide range | Android TV | Installer ecosystem, brand heritage |
| ByteFree Outdoor TV | $1,499 | 1,500 nits | Dolby Vision + Atmos | IP55 | 32°F – 122°F | Google TV | Highest brightness + Dolby Vision + HDMI 2.1 + AV-IN |
| Sylvox DeckPro 3.0+ | ~$1,699 | 1,000 nits | HDR10 | IP56 | -22°F – 122°F | Google TV | Highest weatherproof rating, cold-climate range |
| Furrion Aurora Partial Sun | ~$1,699 | 400 nits + Climate Smart | HDR10 | IP54 | Wide range | Proprietary | Vibration-resistant, RV/marine heritage |
| Peerless-AV Neptune Partial Sun | ~$1,499 | Partial-sun rated | HDR10 | IP55 | Wide range | Proprietary | Commercial-grade durability |
