Best Sound Options for Your Outdoor TV Setup
olena
TL;DR:
Outdoor audio is harder than indoor because there are no wall reflections to reinforce low volume — every watt of speaker power matters more outside. The 4 best sound solutions, ranked: (1) Built-in 30W+ hardware Dolby Atmos (like the **ByteFree BF-55ODTV** — good for small to medium patios), (2) Outdoor-rated soundbar ($400–$900 — big performance upgrade), (3) Multi-speaker outdoor system ($800–$2,000 — pro-grade), (4) Buried rock/landscape speakers ($1,500–$3,000+ — whole-yard audio). For most 8–15 ft patio viewing, the TV's built-in 30W Atmos is sufficient; upgrade only if your outdoor space is larger than 400 sq ft or you host frequent gatherings.
Why outdoor TV audio is different
In a living room, speakers benefit from wall reflections that multiply effective volume. Outside, sound propagates away and dissipates — no walls to reflect it back. This means:
A 10W indoor speaker produces "comfortable" volume; the same 10W outdoors produces "quiet"
Background noise (birds, traffic, pool pumps, wind) competes with the TV sound
Dialog intelligibility requires 20–30% more output power outdoors
Bass response drops dramatically (no wall reinforcement)
Rule of thumb: multiply required speaker wattage by 1.5–2× for equivalent perceived volume outdoors.
Option 1: Built-in TV speakers (30W+ hardware Atmos)
Cost: Included with TV · Performance: ⭐⭐⭐ · Best for: 8–15 ft viewing, covered patios
Modern high-end outdoor TVs ship with robust built-in audio. The difference between 20W passthrough and 30W+ hardware Atmos is significant outdoors.
TV built-in audio comparison
TV
Built-in power
Dolby Atmos hardware
Outdoor suitability
**BF-55ODTV**30W✓ HardwareGood for most patios, standalone
Sylvox Gaming Series60W (2×30W) + SubWoofer✓ HardwareExcellent — best in class
Sylvox Cinema Helio60W (2×30W)✓ HardwareExcellent
Samsung The Terrace~20W✓ Some modelsNeeds soundbar for large spaces
SunBrite Veranda 32×10W (20W)Passthrough onlyInadequate — requires soundbar
Sylvox Deck Pro 2.0Wattage unpublished✓ HardwareLikely adequate
Furrion Aurora2×8W (16W)No AtmosRequires soundbar
Element EP5002×10W (20W)NoInadequate
When built-in is enough
Covered patio up to ~400 sq ft with normal ambient noise
Viewing distance 8–15 ft from TV
Casual viewing (news, sports, streaming) vs cinematic experience
No frequent large gatherings (parties, watch parties with 10+ people)
For the typical **BF-55ODTV** covered-patio installation, built-in 30W hardware Atmos handles the job without additional hardware.
When you need more
Outdoor space 400+ sq ft
Open patio without overhead cover (sound disperses faster)
Pool deck with pump noise, splashing, conversation
Frequent entertaining with groups of 6+
Option 2: Outdoor-rated soundbar
Cost: $400–$900 · Performance: ⭐⭐⭐⭐ · Best for: Medium to large patios, frequent entertaining
An outdoor-rated soundbar below the TV provides substantial audio upgrade.
Soundbar
Price
Power
Notes
Sylvox S3 Outdoor Soundbar$39980WPairs natively with Sylvox TVs; works with any HDMI TV
Sonos Outdoor by Sonance$1,498VariablePremium build, multi-speaker expandable
Klipsch AW-650 Outdoor$299/pair75W eachRock-style speakers, not strictly a soundbar
SunBrite All-Weather Soundbar$699100WMatched to SunBrite TVs
What to look for
IP55 or higher rating (same standard as outdoor TVs)
UV-resistant grille (black or neutral colors last longer)
eARC HDMI or optical input (for Dolby Atmos passthrough from TV)
Mounting bracket (wall mount under TV; tabletop option)
Minimum 60W combined power for outdoor use
Connection to TV
HDMI eARC (best): carries Dolby Atmos + TrueHD audio
HDMI ARC: carries Dolby Digital
Optical cable: older standard, stereo-only in most cases
Bluetooth: convenient but lossy; not ideal for cinematic audio
The **BF-55ODTV has HDMI eARC** — full Dolby Atmos passthrough to any compatible soundbar.
Option 3: Multi-speaker outdoor system
Cost: $800–$2,000 · Performance: ⭐⭐⭐⭐⭐ · Best for: Large patios, custom installations
Dedicated outdoor speaker pairs positioned around the listening area. Wired via buried or hidden speaker cable back to an amplifier.
Typical system components
Amplifier/receiver ($400–$1,000) — outdoor-rated or indoor amp with outdoor-compatible speaker outputs
2–4 outdoor speakers ($300–$1,200 for the set) — on-wall, rock-style, or hanging
Subwoofer (optional) ($300–$800) — for bass, especially for movies/music
Speaker cable ($2/ft × 50–100 ft) — direct burial rated
Sonance (premium)
Yamaha (mid-tier)
Polk Audio (value)
Klipsch (mid-to-premium)
JBL (value)
Installation considerations
Running speaker cable requires buried or wall-routed conduit
Amplifier needs weather-protected location (covered shed, garage)
Speaker positioning: 45° angles from TV viewing position
Wire the system for stereo (left/right) or 2.1 (+ subwoofer)
This option is excellent for dedicated outdoor entertainment zones where the TV is central but audio extends beyond the immediate viewing area.
Option 4: Buried rock/landscape speakers
Cost: $1,500–$3,000+ · Performance: ⭐⭐⭐⭐⭐ · Best for: Whole-yard audio, pool areas, gardens
Rock-shaped or landscape-integrated speakers buried/camouflaged in the yard. Multi-zone audio with professional installation.
When it's worth the cost
Homeowners with large yards (1,000+ sq ft outdoor living)
Whole-property audio desired (pool, patio, dining area, garden)
Renovation or new construction (can bury cables during landscaping)
Value-add for resale (quality systems add 1–2% to property value)
Typical costs
4–6 zone system: $2,000–$5,000 installed
Whole-property 8+ zones: $5,000–$10,000+ installed
Control via app, voice, or wall panels
Integration with outdoor TV
Zone the TV sound into "patio main zone" — when watching TV, audio plays on patio speakers. Other zones can play different audio (or be silent).
Which option is right for you?
Scenario
Best sound option
Budget
Small-medium covered patio, casual viewingBuilt-in BF-55ODTV 30W Atmos$0 extra
Patio with frequent guest gatheringsOutdoor soundbar ($400–$900)+$400–$900
Large open patio (400+ sq ft)Soundbar + subwoofer+$700–$1,400
Pool deck + dining area combinedMulti-speaker system+$1,500–$2,500
Whole-yard audioRock/landscape speakers+$2,500–$10,000
Commercial outdoor bar/restaurantMulti-zone commercial system$5,000+
Common mistakes to avoid
1. Indoor soundbar outside
Indoor soundbars (even high-end Sonos Beam, Samsung HW series) fail outdoors within 1–2 years from humidity. Use outdoor-rated only.
2. Wireless speakers exposed to weather
Bluetooth/Wi-Fi speakers not rated for outdoor use fail quickly. Sonos Outdoor line is OK; generic Amazon wireless speakers are not.
3. Underpowered system
A 30W system works for 200 sq ft; trying to cover 800 sq ft with the same power produces tinny, thin audio. Match power to space.
4. Speaker cable not rated for direct burial
Indoor speaker cable rots when buried. Use direct-burial rated (CL3 or UF rated) cable.
5. Skipping the subwoofer for movies
Outdoor environments strip bass most dramatically. A subwoofer dramatically improves movie/music experience — worth the $300–$800 addition.
FAQ
Do I need a soundbar for my outdoor TV?
Depends on TV built-in audio and patio size. A BF-55ODTV with 30W hardware Atmos on a small covered patio: no soundbar needed. A SunBrite Veranda 3 with 2×10W stereo on a large open patio: definitely yes.
Can I use my indoor soundbar outside under a covered patio?
Only in fully enclosed climate-controlled spaces. Indoor soundbars fail under open covered patio conditions within 1–2 years.
Will a Sonos system work outdoors?
Sonos Outdoor by Sonance is outdoor-rated and works well. Standard Sonos (Beam, Arc, Era) is not outdoor-rated — use under full climate control only.
How loud do my outdoor speakers need to be?
For comfortable conversation-level TV audio 10 ft away: 65–70 dB. Most 30W+ outdoor systems handle this comfortably. For party volume (75–85 dB), step up to soundbar + subwoofer or multi-speaker system.
Does Dolby Atmos matter outdoors?
Yes, but less than indoors. Indoor Atmos benefits from ceiling reflection to create height effects. Outdoors, Atmos provides better dialog intelligibility and width, but height effects are minimal without overhead reflective surfaces.
Can the BF-55ODTV drive an external soundbar?
Yes — BF-55ODTV has HDMI eARC which passes through Dolby Atmos to any compatible soundbar without quality loss. Plug and play.
Verdict
For 80% of residential outdoor TV installations, the built-in 30W hardware Dolby Atmos on the BF-55ODTV is sufficient. You can skip the $400–$900 outdoor soundbar expense entirely.
For larger spaces (400+ sq ft) or frequent entertaining: add an outdoor-rated soundbar for $400–$900.
For whole-yard audio or pro-grade setups: multi-speaker or rock-speaker systems at $1,500+.
Shop the ByteFree BF-55ODTV at bytefree.net — 55″ 4K with 30W hardware Dolby Atmos built-in (no soundbar needed for most patios), Dolby Vision HDR, Google TV, IP55, $1,499.
