Can Echo be paired with another identical Echo for true stereo?
Grace's Member Dec 30, 2021 #2 You can designate a left and right speaker with the app. The answer to your question is yes.
N njfdngi Member Dec 30, 2021 #3 Yes. You can either create a group of just the couple/few that you want to work together, or if you want the music to play on all the echos, dots, and shows simultaneously just say "Alexa, play (name your music) everywhere."
M Markkk_4 Member Dec 30, 2021 #4 Do you mean music from two separate speakers? yes, You can set up “groups” of multiple echo speakers.
