Dangbei F1 and Dangbei F1C projector: key difference and which one is better
Xmint
Dangbei F1 and Dangbei F1C are the projectors released by Chinese famous brand Dangbei at 2019. Dangbei F1 and Dangbei F1C projectors both have their own advantages with the common advantages of high configuration, extraodinary system, large memory and super-fast operation. When the key difference between F1 and F1C? It should be discussed by the aspect of appearance, image quality and focus correction technology.
Dangbei F1C (left) and Dangbei F1C projector (right)
Design
Dangbei F1 and Dangbei F1C projector are made of ABS material + craft hemp fabric. The color tone is in harmony with each other. The sense of technology and the minimalist style are perfectly integrated, which is in line with the aesthetics of most consumers.
the difference in the appearance of the f1 and f1c is on the front, the Dangbei F1 lens is seen from the front, it is on the left, and the F1C lens is on the right , which means that the f1 and f1c optomechanics are different. The location, the "dangbei" logo also happens to be the opposite design.
Hardware Configuration
Dangbei projection F1C and Dangbei projection F1 are equipped with Mstar 6A938 processor, with 3GB storage +32GB storage, no boot ads, can fully meet the different download needs of users.
In addition, on the focusing lens between the lens and the logo, F1 has only one larger focusing lens, and F1C has a set of focusing modules, has dual TOF+CMOS cameras, uses laser autofocus technology , focusing speed is faster, performance Show the technical advantages of f1c
Picture quality
Dangbei F1C has a built-in 4K color rendering engine Pro, it has a true 1080P resolution, a brightness of 1300 ANSI lumens, 4K decoding, sensorless auto keystone correction, sensorless autofocus, MEMC motion compensation, global 3D playback, 2D to 3D, 5GWiFi Watch movies, multi-screen interaction.
Dangbei F1 has a physical resolution of 1920*1080 and a brightness of 1400ANSI lumens, it adopts the color image engine, with three functions of debounce, noise reduction and color restoration. It supports MCME+4K HDR10 image quality decoding+autofocus+trapezoid Correction + 2D to 3D + overall 3D.
Operating system
Dangbei F1 and Dangbei F1C projectors are both equipped with Dangbei OS 2.0 flagship system independently developed by Dangbei. It has built-in massive content such as iQiyi, Mango TV, PPTV sports, and wonderful variety shows. Popular videos are continuously updated daily. Freely customize according to your own preferences. At the same time, these two products also use AI intelligent voice, support multiple rounds of dialogue, remote control voice, Bluetooth remote control and other functions, all you want to do is just say a word.
Price
Dangbei F1C is priced at 4199 yuan (around $593.1 ).
Dangbei F1 is priced at 4499 yuan (around $ 635.5 ).
As a projector released in early 2019, Dangbei F1 will be inferior to F1C in focus correction technology , but f1's focus can also be accurate and fast, and it can also support trapezoidal correction and side projection mode , but the correction process requires Fine-tune the picture manually. However, when Dangbei Projector broke through the two major problems of the trapezoidal correction and autofocus of the projector within one year, the technology is indeed progressing rapidly. At present, only projectors that support automatic keystone correction technology are XGIMI and Dangbei, but only Dangbei supports non-sensing focus.
The brightness of the f1 and f1c is different. The f1 brightness is 1400ANSI lumens, the f1c brightness is 1300ANSI lumens , and the higher brightness of f1 will affect the quality of the projected picture. With rendering power, f1 will look slightly better than f1c in a lighted environment. In terms of contrast, Dangbei f1 has a high contrast of 8001-10000:1. In the contrast of the picture, the image of Dangbei f1 has a more vivid experience. As for the display chip, when the F1C uses 0.33DMD display chip, when the F1C uses 0.47DMD display chip , the resolution can reach the level of 1080P, but the way of implementation is different. This is also the reason why the prices of f1 and f1c differ.
Tyler123
I think F1C is just the first product of Dangbei involved in fully automatic technology, not the new flagship of F1.
This tech is also used in their next generation flagship model Dangbei F3
