venice123
With the popularity of smart projectors, enjoying movie-quality big-screen viewing at home is no distant dream. Today's smart projection, not only play more, strong performance, the price has been able to match with the mobile phone, so many families have projector into the must choose one of the household appliances. Projection is good, but the configuration and function of each brand is not the same, how to spend the least money, to buy the most appropriate projection has become the key, today the author in the way of evaluation, and you share a very hot recently when the shell F1C smart projection, to see whether this projection is worth buying.
The reason why I evaluated this smart projection of dangbei F1C was also a comparison, and I found that among many flagship projection products, dangbei F1C has great advantages in both price and configuration. Industry, in addition, the homogeneity serious projection when Mr F1C pioneered non-inductive automatic trapezoidal correction and non-inductive autofocus black science and technology, it is a great breakthrough innovation function, can be largely solved the effects of environmental factors on the projection screen, so that the projection is more suitable for use in all kinds of home environment. So how does this projection work? Still come to experience together!
Apart from the packaging, it can be seen that the figure of the smart projection of donberg F1C is not large. After looking at the size in the instructions, the volume is only 255mm * 183mm * 84mm, and the net weight is about 2.1kg. It belongs to the petite type, so it won't take up too much space.
In terms of appearance, basic continuation when Mr On the design of the flagship model of F1 generation, the fuselage of the cuboid shape, appearance design aspect not to say jing is colourful, but also look not mediocrity, silver metal with colored cloth art collocation, make whole very rich sense of science and technology, and can fit all kinds of household style very well.
On the front of the body, the projection lens of sapphire lens is adopted, and the projection light source technology of RGB LED and DLP display technology are applied. The light bulb brightness is 1300 ANSI lumen, equivalent to the light source brightness of 3600 lumens. The maximum resolution can reach 1920X1080 DPI, supporting 4K resolution and active shutter 3D technology. At the same time, MEMC dynamic thermal compensation technology is also incorporated, which can effectively reduce the problem of running focus and virtual focus, and solve the problem of picture blocking and tail dragging in the movie. From this alone, we can see that dang bei F1C is quite sincere.
Next to the lens, is the product's dual TOF + CMOS camera module, which can be said to be a big highlight of the dangbei F1C. The dual algorithm of dual TOF + CMOS camera realizes chip-level senseless automatic trapezoid correction and senseless autofocus, which is essentially different from the way of focusing through software. For our users, the most intuitive feeling is to save the focus of the picture steps, even if the projector is moved halfway, the picture will automatically focus with the change of the projection, always let the projected picture to show the best display effect.
In terms of buttons and interfaces, all the integration can be seen in the rear of the body, in addition to the power button on the left, the lower part is equipped with S/PDIF audio jack, network interface, HDMI hd output interface, two USB 3.0 interface and power jack, in terms of expansion can fully meet our daily use. And out of sight, the dangbei F1C has a built-in 5G wifi network that can connect to the 5G network of an AC router, giving it higher transmission speeds and lower channel interference.
Look on either side of the fuselage at first seemed no different, but look carefully you can see, the left side of the grille hole is F1C speakers, although the volume of a body is not big, but when Mr F1C didn't sound on shrinking, and also has carried on the substantial upgrade to sound cavity, can provide descend to 100 Hertz, the bass level, while viewing, immersive sound shadow effect.
On the right side is the product of cooling hole, with internal heat sinks, copper pipe and fan, in the operation of the equipment, heat will be fan export, then through the radiator grille, so in the operation of the equipment, will send out the voice of the fan rotation, but fortunately when Mr F1C equipped with high efficient mute fan, so the noise is not obvious, but the specific how to noise, the author will make a test later.
The bottom design of dangbei F1C is simple and clear. In addition to the product parameter information, the screw hole of the bracket is reserved in the middle to support normal placement and hoisting. Additional, bottom all round still tie-in the non-slip foot that can adjust height, pass the fine-tuning of height of non-slip foot, can let projector apply to put environment more.
The remote looks very similar to a normal TV box, with the same buttons and layout, as well as support for voice input. The only difference is, when Mr F1C designed a remote control key side, the side key support according to short and according to the function of the long, long press can realize automatic focus, and short press can quickly bring up the Settings menu, rapid positioning to 3 d function, motion compensation, focus, task switching, Settings, and so on common functions, eliminating the return set operations, such as just a key can be adjusted.
