SuperM
Dangbei F5 as a new product in 2022, attracting a lot of attention, this article is Dangbei F5 projector review, to see if this 1080P projector is worth buying.
Dangbei F5 follows the square design of the Dangbei F series, this is the first time in the F series of products to add a touch glass design.
In the hardware configuration, Dangbei F5 and the previous generation of Dangbei NEW F3 also have a big upgrade, using the MT9669 chip, while adding DOBLY & DTS sound, equipped with a high-power amplifier, so that Dangbei F5 in the hardware level has a qualitative leap.
Dangbei F5 has AI color engine picture quality technology, through ai real-time calculation, to show you a more realistic and delicate restoration of the picture. At the same time [email protected] MEMC motion compensation technology plus HDR high dynamic range technology, so you can feel the motion picture without dragging. The ultra-low latency of 16ms gives gamers a smooth picture.
Now let's take a look at the actual screen performance of Dangbei F5. In terms of brightness, Dangbei F5 cooperates with OSRAM and adopts OSRAM's new generation of high-brightness P1MR lamp set, which, in terms of brightness, can be said to be the brightest representative of the current LED light source projection.
