Trummpy
The trend of large screen entertainment is irreversible. It is not an option for smart TV to experience large screen in living room. Even for most users, smart projector has more advantages in cost performance and portability. The brightness of 2050ansi lumen, with 4GB + 64GB super large storage, supporting automatic non sensitive focusing and automatic trapezoid correction, and the MEMC motion compensation up to 120Hz frames, etc. most of these functions are highly demanded by projector users, which is equipped by Dangbei's latest product, the Dangbei projector F3. What is the performance of such a powerful projector F3?
On the right side of the projector F3 is a dual TOF time-of-flight sensor. Combining with the CMOS camera algorithm, it can achieve fast non sensitive focusing. At the same time, it can also achieve automatic trapezoid correction by calculating the trapezoid change. It can solve the user's two requirements of focusing and trapezoid correction. In the actual experience, the effect of auto focus and auto trapezoid correction is very good, and the feedback is very fast.
The lens on the left side is also quite excellent. When the F3 of bexproject is upgraded to use the LED light set of German OSRAM's new RGB + B 4-channel architecture, and the 0.47’’ DMD display chip is used, it has as high as 2050 ANSI lumen brightness. Even when the light is sufficient in the daytime, it can output a clear picture. At night, the projection brightness and the picture quality are completely comparable to that of TV.
On the back, Dangbei projectorF3 has a rich interface configuration, from left to right are power interface, USB3.0 × 2, HDMI, HDMI (ARC), LAN network interface, S / PDIF and 3.5mm headphone hole. Rich interface means more diversified playing methods and expansion, such as HDMI (ARC) interface, which supports access to game consoles. Moreover, Dangbei projector F3 also has two USB 3.0 interfaces as standard.
When the Dangbei projector F3 also increases the heat dissipation, the effective heat dissipation will also control the running noise at a lower level, and the machine will run for two or three hours without hearing the wind noise.
When the standard voice Bluetooth remote control of Dangbei projector F3 continues the classic design, the side magic key, home key and AI intelligent voice key are integrated in a variety of interaction modes, and the remote control is retrieved, multitask processing, focusing, and convenient menu are brought out at any time. The human-computer interaction is smooth.
Dangbei projector F3 System and Content
Dangbei projector F3 uses the light, fast and free OS system of Dangbei. Through innovation, the OS system of Dangbei projector F3 is more intelligent, and combined with the built-in intelligent memory optimization technology. It can keep the system in good condition at all times. The home page content classification menu can be customized according to the user's preferences, and the sorting, addition and deletion are left to the user's discretion. The shortcut function can also edit sorting.
Thanks to the support of hardware dual TOF + CMOS camera, Dangbei projector F3 supports the function of non sensitive auto focus and non sensitive auto trapezoid correction.
Insensitive autofocus
In addition to focusing, the most headache for projector users should be to move the picture slightly and then adjust the trapezoid again. Dangbei projector F3 supports automatic trapezoidal correction, it can generate a square picture immediately without worrying about the problem of virtual focus caused by the movement. Because the automatic trapezoidal correction will focus first and then correct spontaneously, which is quite convenient.
Senseless automatic trapezoid correction
Compared with the previous generation of products, Dangbei projector F3 also supports far-field voice, and does not want to use the remote control or mobile phone remote control, just turn on the machine, say the wake-up word "Hello, Dangbei", then say your needs, you can free your hands to watch the movie easily, and the evolving intelligent voice also supports multiple rounds of dialogue. When the 4-mic matrix on the F3 top cover is projected, accurate far-field pick-up can be achieved, both speech recognition and feedback are relatively accurate and rapid.
Dangbei projector F3 music and image experience
Rich content is the basis of user experience, how to present these content with excellent image quality is an important step to improve user experience. Dangbei projector F3 has 2050 ANSI lumen brightness, equipped with color rendering engine pro, with color restoration, noise removal and other functions, plus F3 supports hdr10, HLG high dynamic video decoding technology, it can easily achieve 4K ultra-clear decoding image quality output. Not only that, in the processing of motion video or game screen, when the Dangbei projector F3 also supports the MEMC motion compensation technology, the refresh rate can reach up to 120Hz, which is the leading level in large screen.
Dangbei projector F3 performance
From the restoration of image quality and sound quality to the smooth operation of the system, performance driving is indispensable. Dangbei projector F3 is equipped with Mstar6A938 flagship chip with upgraded architecture, 4GB + 64GB super storage is built in, and it supports 2.4g/5g dual frequency Wi-Fi and Bluetooth wireless connection technology of Broadcom. In terms of chip decoding ability, it supports Hevc, VP9, H.265 and other mainstream 4K encoding formats, as well as global 3D playback. When the performance configuration of Dangbei projector F3 is upgraded a lot compared with the previous generation, even in the whole family intelligent projector industry, this configuration is also ranked high.
