Gabe
Dangbei X3 VS. JMGO J10
1. In terms of the brightness of the projector, Dangbei X3 projector is brighter than JMGO J10, the brightness of Dangbei X3 is up to 3200ANSI lumens, the brightness of the JMGO J10 is only 2400ANSI lumens.
2. Dangbei X3 adopts laser light source, JMGO J10 still uses LED light source. The laser light source has high brightness, low temperature and purer color, which has been considered as the future development trend of projector light source;
3. In configuration, Dangbei X3 and JMGO J10 use MTK9669 processor, running memory is also 3GB, but in the storage space Dangbei X3 reached 64GB, JMGO J10 storage space is 16GB, there is a big difference;
4. In terms of volume, the nut J10 is smaller than Dangbei X3. The length, width and height of JMGO J10 is 220*220*150mm, while the length, width and height of Dangbei X3 is 246*209*173mm. Dangbei X3 weighed 4.6kg, nut J10 weighed 3.3kg, Dangbei X3 was also heavier.
