Dangbei Projector
What are the biggest difference between physical resolution and display resolution?It is whether they can be adjusted. Physical resolution refers to the maximum number of pixels that can be displayed on the display screen. It is an inherent parameter and cannot be adjusted. Display resolution refers to the resolution of the display screen when displaying images. Adjust the resolution of the screen display in the settings.
Difference between physical resolution and display resolution
The biggest difference between physical and display resolution is whether it can be adjusted. Physical resolution, also known as true resolution, refers to the maximum number of pixels that can be displayed on the display. It is an inherent parameter and cannot be adjusted; while display resolution refers to the resolution of the display when displaying images, you can adjust the screen in the settings The resolution of the display.
| Expanded content: Whether it is physical or display resolution, the larger the value, the clearer the image. However, because the display resolution can be adjusted, if you want to connect the computer to the projector, you need to set the display resolution within the range of the projector resolution. |
