Robert
It can be frustrating to watch your favorite TV show or movie with no sound on your TV. Most of the time, the TV is probably muted. But sometimes it can be something else. This guide will address TV has no sound but not muted.
When there is no sound or picture on the TV, you can first check to see if there is a problem with the mute setting on the TV. If the user accidentally presses the mute button on the remote, the TV will not sound.
If you mute the TV, there will be no sound. Press the mute button on your TV or remote to unmute it.
The audio and video cables on the TV must be connected before using the TV. If the audio and video cables on the TV are not connected correctly, there will be no sound when using the TV.
The audio and video cable of a television consists of audio cables and connectors that need to be reconnected to the audio and video cable of the television when there is no sound in the television.
When using a TV to watch a program, the volume on the TV or set-top box is set to a minimum, so the TV has no sound.
When troubleshooting, adjust the volume of the TV or set-top box again.
A failure of the power board can also cause the TV to go silent.
When the power board of the TV is out of order, it is best to have it repaired by a professional.
Fix TV has no sound but not muted
Wrong settings
The audio and video cables are not connected
Low volume
Power board failure
