WilliamP
This article will show you Haier TV WiFi not working solutions.
1. Go to the Network Settings to check if you turn on the WiFi connection.
2. Check your wireless router Settings, make sure the wireless signal is normal, you can turn it off and back on.
3. Restart your Haier TV.
4. Make sure the WiFi device is not too far from your TV.
5. If the solutions above do not work, try to reset the Haier TV.
