loughborough
The intelligent smart alarm is a common fire warning device, which can accurately sense the smoke produced by the fire at the early stage of the fire and quickly warn people. Smart alarms are generally installed in homes, Internet cafes, nursing homes and other places to detect smoke and other disasters.
smart alarm1: Nest Protect
smoke and carbon monoxide smart alarm, if smoke or carbon monoxide is detected, the smart alarm will have a voice reminder to tell which location is having a problem, and the battery will be sent when the battery is low. The mobile phone can check the smart alarm status and operation, such as turning off smart alarm. If there is a Nest thermostat, the carbon monoxide alarm will also cause the thermostat to turn off natural gas heating.
If you think it is too expensive to replace all the smart alarm in your home with smart versions, you can consider the following products.
smart alarm 2: Leeo
smart monitor, no need to install it, just download it from the power outlet, the principle is to monitor the sound of the original alarm, if the original smoke / carbon monoxide alarm sounds, it will Send a notification to your mobile phone, and provide a hotline of the relevant local department according to the home address you set. If the owner of the mobile phone does not respond, you can also contact your relatives and friends.
smart alarm 3: Roost
smart 9V battery is suitable for all smoke / carbon monoxide smart alarms powered by 9V battery. The smart battery can be connected to the mobile phone via Wi-Fi to send an smart alarm. When the battery is low, the mobile phone will send smart alarm a reminder. When a fire alarm occurs, the smart alarm can also automatically send a reminder to relatives and friends. If it is a 9V battery-powered alarm, you can also turn off the alarm through the mobile app. Officially, battery power can last for 5 years.
smart alarm 2: Leeo
