how do i fix the sound on my philips tv?i cannot get any sound on the philips tv.
Check the sound volume and mute mode on Philips TV
If there is no sound on your Philips TV, please check the volume. Also, check to make sure the mute function is activated.
While these steps are simple, they are usually one of the easiest to overlook when it comes to TV sound problems.
The mute function is usually controlled by the remote control, so if it cannot be turned off, replace the batteries.
If you have any devices plugged into the headphone jack, unplug them.
Sometimes, the TV will automatically mute the audio when headphones are plugged in.
