Xmint
A: First of all, Epson Home Cinema 1060 Projector color gamut is: 88% sRGB, 66% NTSC, 70% AdobeRGB (average value after multiple proofreading). For its color gamut realization, it can be seen that the color reproduction degree using 3LCD technology is quite good, this color gamut value is quite good in the low-end projector. As for its sharpness, it is true 1080p physical resolution. The sharpness is good. The sharpness is related to the distance of the projection. The larger the distance, the lower the distance.
You can use the official projection distance calculator to evaluate the use environment to adjust the placement of the projector. position.Epson Home Cinema 1060 Projector does not have video smoothing technology such as frame insertion, and there is still a certain smear for high-frame conversion scenes, such as the picture of racing football. When you look closely when using it, you will still see particles, but this is only a very close observation. In fact, when watching movies or playing games or in the office, there will be a certain distance from the projection screen. The following two pictures show the fineness of viewing screen images from a distance and a close distance.
