BladeW
How is the sound quality of headphones defined? What kind of experience is good sound quality? Headphone sound quality is generally expressed from the following aspects.
1. Resolution can be simply understood as the ability to restore details. Good headphones, you can hear many details, such as a small vocal chorus, the friction of the hands and strings, the sound of ventilation when singing, etc. With good headphones, you will feel a gap between watching black and white TV and watching HD TV.
2. The low frequency dive can be simply understood as the feeling of "moving times and playing times". Refers to the extremely low frequency performance of the earphone, which is a "slap feeling" to the eardrum in the sense of hearing. The low-frequency performance of a good dive headset is three-dimensional, and the head has a "shock". This kind of feeling is a bit like the feeling of bass vibrating the body when singing in ktv.
3. Good headphones on the scene will make you forget the existence of the headphones themselves, you will feel the feeling of being on site. Musical instruments and human voices are transmitted from different directions, and the scene is very strong. The size of the sound field represents the breadth of this "space".
4. Good hearing resistance arphones are less prone to fatigue because the sound is more real, just like the sound of nature in daily life. Listening to music with headphones with good sound quality for hours is a kind of enjoyment. Instead of using headphones with poor sound quality, a certain frequency band is too prominent, and you will feel very tired after listening for a long time. When you take off the headphones, you will find that it is a feeling of relief. Some earphones have too low frequency, and if you listen for a long time, there will be a stuffy feeling.
Identification method of the sound quality of the headset
1. Frequency response: This parameter is one of the very important indicators for evaluating the quality of the headset.
2. Maximum sound pressure level, or sensitivity: The meaning of these two parameters is the same. The higher the sensitivity, the easier the headset is to make sound and the easier it is to drive.
3. Whether to listen for long time: Good headphones have very natural sound just like the sound of nature in our daily life and people are not prone to fatigue about the sound.
4. Whether the resolution is good: With good headphones, you can hear many details, such as a small vocal chorus, the friction of the hands and strings, the sound of ventilation when singing, etc.
5. Whether the sense of immersion is good: Good headphones will make you forget the existence of earplugs, and you will feel the feeling of being on site. Musical instruments and human voices are transmitted from different directions, and the scene is very strong. If you think the sound is coming from the headphones, then the headphones are so-so.
6. Headphone material: Headphones are not 100% good with excellent materials. But the headphones are definitely not good with poor materials and poor workmanship.
Therefore, we generally buy headphones, and actually find the headphones that are really suitable for us.
1. Be sure to clarify your requirements. First, the difference in front end plays a decisive role for headphones. The thrust of front-end audio sources such as mobile phones and MP3s is not great. It is more suitable for earplugs and portable headphones, while computers and desktop CDs It is a high-thrust sound source, and most headphones are compatible. At this time, we can consider some full-cover headphones and high-impedance products.
2. Focus on listening and understanding. The most important thing is to listen to the earphones, but not every product is suitable for you. For example, some earphones sell more, many users feel that the sound quality is good, but you may not feel how after you buy it. In fact, the important thing about headphones is their own feelings, just like listening to music, some like rock music, and some people like pop music or DJ dance music. The same is true for headphones. Different types of concerts have different earphones that match best. In addition, different power digital products are suitable for different headphones.
3. Determine the type of headphones you want. Another point is what type of headphones you like. Different types or appearances of headphones can be selected according to your users or preferences. These are mainly based on feelings, but you also need to have some understanding of these types of headphones. , Choose from a variety of styles that suit you.
4. Take a closer look at the product parameters. For headphones, two models use same unit and parameters through the training of different engineers, the sound will change greatly, but for the purchase of headphones, the parameters are only for reference, not the most important, but it can never be ignored.
