How is Xiaoming Q2 Pro projector?
Graceli
Xiaoming Q2 Pro projector is now released, true 1080p physical resolution + 800ANSI lumens. What do you think of the Xiaoming Q2 projector?
Xiaoming Q2 Pro projector is used for 800ANSI lumens, which is 33% higher than the previous generation. It adopts true 1080p physical resolution and supports HDR10+ decoding. Moreover, Xiaoming Q2 Pro projector is equipped with Dolby AUDio 2*3W speakers, configured with Amlogic T982 processor, 2GB memory + 32GB flash memory.
