How to charge Anker Nebula Mars projector?
Timins
Anker Nebula Mars projector is a portable projector with a built-in battery, so it can be used outside without charging if is have been full charged. Here is how to charge Anker Nebula Mars projector.
What's in the box when you buy Anker Nebula Mars projector?​
The package comes with Anker Nebula Mars projector, remote control, quick start guide, and charger.
How to charge Anker Nebula Mars projector?​
1. When you unbox the Anker Nebula Mars projector, take out the projector, remote, and charger.
2. There are two parts of the charger. Plug on end into the Anker Nebula Mars projector, and the other end with the charging cable, and then plug the charging end into the socket. LED indicators will light on when the battery is charged.
3. You should fully charge the built-in battery before using for the first time. And then you can enjoy the movie night with Anker Nebula Mars projector anywhere.
