Just as smart phones shine and non smart phones disappear 10 years ago, at present, smart TV is also in the era of shine, and non smart TV is more and more difficult to buy in the market. Why buy smart TV instead of ordinary TV + TV box?
Ordinary non intelligent TV has been difficult to find 4K definition. Even if there is, the price is almost the same as that of intelligent TV with the same definition. Non intelligent TV has no advantage. Intelligent TV can be controlled by only one remote control. Ordinary TV + box needs two remote controls. It's hard to find one at home, let alone switch back and forth between two remote controls. It's too troublesome.
At present, almost all major TV manufacturers have gone to develop and produce smart TVs. They will no longer continue to invest in non smart TVs, for fear that they will die like Nokia Motorola. Non smart TVs and non smart phones are being quickly eliminated. Without TV hosts, the parasite of TV boxes will soon die.
A few years ago, smart phones strangled non smart phones, and now in the field of television. After all, there are two bodies of Nokia and Motorola in the public, Internet TV businesses are frantically seizing the market, traditional TV manufacturers are endangering themselves. Smart TV purchase method (main hardware aspects), which hardware is the key, see below:
How to choose a smart TV?
Budget: less than 4000 yuan.
Screen size: 49 inch, 50 inch, 55 inch smart TV
Required parameters during purchase:
Screen: original LG IPS, original Samsung screen, etc. (RGB true 4K screen)
Processor: cortex-a57 processor, cortex-a53 processor (a57 > A53 in performance)
GPU: arm mali-450 MP4 and above (generally select the CPU, GPU will not be bad)
Running memory RAM: at least 2GB
Storage space ROM: at least 8GB
Bluetooth: Bluetooth Four Above, it is better to support Bluetooth voice remote control.
Operating system: Android at least
Interface: at least one USB Three , at least one HDMI Two (or HDMI arc)
Advertisement: Choose TV without ads if you hate it. This can be compromised as appropriate.
Source: see clearly whether to send members or not. Those who send members also need to ask how much is the annual fee when it is due. There are not enough movie sources on this computer. You can download apps to open membership expansion.
Refuse to buy parameters: some brands of smart TV can't even install third-party software! This kind of setting must be asked clearly in advance! I won't name and criticize!
Screen: RGBW 4K
Processor: too backward to consider. For example, cortex-a15 processor, cortex-a12 processor, cortex-a9 processor, cortex-a8 processor, cortex-a7 processor and cortex-a5 processor.
Running memory RAM: less than 2GB, such as 1.5GB , 1GB, 768mb, etc.
Bluetooth: not supported
Operating system: some yunos systems do not support the installation of third-party software. Interface: only USB2.0 And HDMI One point four.
Be careful when you choose a smart TV
Hardware parameter explanation: screen: the display effect of IPS hard screen and VA soft screen is basically the same, without tangle. 4K screen is much more complex. RGB and wrgb are both real 4K screens, which are expensive and display effect is good. You can tick to choose. RGBW (four color 4K) is a fake 4K. The display effect is worse than the real 4K. The price is cheap. It is not recommended to choose. When you buy it, ask clearly. If you are not told, it will be a fake 4K by default. RGB true 4K, IPS hard screen. Four color 4K, RGBW, blow well, but it's fake 4K.
Processor: the quality of the intelligent TV processor directly affects the running speed and fluency. At present, the manufacturers of the intelligent TV CPU are mainly MSTAR (Morningstar semiconductor) and AMLOGIC (AMLOGIC semiconductor), both of which use arm architecture. Generally, the manufacturers will mark the processor as A53 or a57, which can be selected by checking. If you only mark the number of cores, you should be careful. You need to ask whether it is cortex-a53 or cortex-a57 or something else.
Running memory: it is also closely related to the running speed and fluency of smart TV. You should buy 2GB, and try not to buy below 2GB. DDR4 has better memory particles than DDR3.
Storage space: the size of the storage space means how much software you can install on the TV, how many videos you can place, how many songs you can play, etc. it is mainly used to install the software. It is better to choose the storage space of 8GB and above.
Bluetooth: to support Bluetooth Four Above, what is the use of smart TV supporting Bluetooth? It can be used to connect the game handle of Bluetooth audio headset remote control, etc., which is quite important. For example, if the sleeper wants to sleep but you want to watch TV, you can connect the Bluetooth headset without disturbing each other.
Interface: must have at least one USB3.0 (for high-speed reading of video in USB disk hard disk) and a HDMI2.0 Interface (for HD connection), USB2.0 Low speed reading and writing, HDMI1.4 Not either.
Some parameters are not written in the introduction, customer service is also hesitant to ask or answer questions, then you should be careful, most likely this parameter is lower than expected. Some seemingly unimportant parameters can represent the overall hardware configuration, which is very interesting. For example, Bluetooth is not supported, or only USB2.0 , no USB3.0 Interface, then the whole hardware is likely to be low configuration. On the contrary, there are two HDMI2.0 Interface or two USB3.0 The interface and the hardware of the whole machine are not too bad. Hope this article is useful for you to choose smart battery!
Screen: RGBW 4K
