Fire TV cube provides impressive images and bright colors. Although its sound effects are good, if you pair it with a soundbar to match the picture, the experience will be perfect. That's what many people exactly want to do with it. However, users are confused about how to connect FireTV Cube to soundbar. Here you will find a detailed operation guide.
Method 1: Connect Fire TV Cube and Soundbar via HDMI
Preparation: Two HDMI cables, soundbar, Fire TV Cube and TV monitor
To connect an Amazon Fire TV streaming device to the best soundbar of your choice, you need to connect all three devices (the soundbar, Fire TV Cube, and TV monitor) together. The first method to connect Fire TV Cube and Soundbar is HDMI, which is the most reliable and stable connection method that supports the highest quality audio.
1. Connect Fire TV Cube and Soundbar
To connect the Fire TV Cube to the soundbar, locate the HDMI port on all devices and plug the end of the cable into the correct input. You will need two HDMI cables. Plug one end of one of the HDMI cables into the HDMI input interface of the Fire TV Cube, and plug the other end into the output interface of the Soundbar.
2. Connect the Soundbar to the TV
Select the correct source on the soundbar by entering "Settings" or finding the "Source" button on the remote control. After changing the input source, the next step is to connect the soundbar to the TV using another HDMI cable. Insert the end into the marked port, and then select the correct audio source on the TV.
The connection should be Fire TV cube to soundbar to TV. If this doesn't work, try going from Fire TV to TV to soundbar.
3. Log in to your Amazon account
After that, if you need to take any additional setup steps—such as logging in to your Amazon account—a prompt should appear on the screen to prompt you for instructions.
Method 2: Connect Fire TV Cube and Soundbar via optical fiber
Another option on how to connect the Fire TV Cube to the soundbar you may encounter is a digital optical connection, which also supports high-definition audio, but the quality is not as good as HDMI. The specific connection method is similar to method 1, as long as the connection between the TV monitor and the Soundbar is changed to an optical fiber connection, and the other steps are the same.
Since Fire TV Cube runs on HDMI, it is important to ensure that both your soundbar and TV support this type of connection. If not supported, you can use fiber optic connection.
How to connect Fire TV Cube to Soundbar?
