JIRENO CUBE4 projector supports both wired and wireless connections
1. Wireless connection
JIRENO CUBE4 supports 2.4GHz and 5GHz dual-band WiFi, so you can connect your phone to it easily.
2. Wired connection
JIRENO CUBE4 provides a USB port and a Type C port, so you can connect your Android phone or iPhone via a cable.
