There are two ways to return to the TV system after the TV screen is cast. They are to disconnect the screencast connection from the mobile phone or use the remote control to exit. The following is a detailed description of the detailed steps for disconnecting the screencast connection from the mobile phone.
Method 1: Disconnect the screencast connection from the phone
1. Open network settings
Open the network settings interface on the mobile phone;
2. Disconnect the Internet
Tap the wireless network you are connecting to to disconnect the screencasting connection.
Method 2: Use the remote control to exit
1. Find the return key
Find the back button on the TV remote;
2. Click the back button
Click the back button on the remote control to confirm the exit screen projection.
How to return to the TV when TV is screencasting?
