How to Get Apple TV on Smart TV? Ultimate Guide
Want to enjoy Apple TV+ content like “Ted Lasso” and “Severance” on your Smart TV? You’re in luck—Apple has made it easier than ever to access its streaming platform across most major smart TV brands.
Here’s everything you need to know about how to get Apple TV on a Smart TV, including step-by-step installation instructions, compatible models, and troubleshooting tips.
Is Apple TV Available on Smart TVs?​
Yes! The Apple TV app is available on most Smart TVs made after 2018 from top brands like:
  • Samsung
  • LG
  • Sony
  • Vizio
  • TCL (with Roku or Google TV)
  • Hisense
This app gives you access to both:
  • Apple TV+ (Apple’s original content)
  • Your iTunes purchases and rentals
  • Other channels like Showtime, Starz, and Paramount+
How to Get Apple TV App on a Smart TV (Step-by-Step)​
Here’s how to install the Apple TV app on the most common Smart TV platforms:
Samsung Smart TV (2018+)​
  1. Press the Home button on your remote.
  2. Go to Apps.
  3. Select the Search icon (top right) and type “Apple TV”.
  4. Select the Apple TV app and click Install.
  5. Open the app and sign in with your Apple ID.
✅ Works with: Samsung models from 2018 and later (Tizen OS)
LG Smart TV (webOS 4.0 and above)​
  2. Navigate to the LG Content Store.
  3. Use the search bar to find “Apple TV”.
  4. Download and install the app.
  5. Sign in with your Apple ID or create one.
Sony Smart TV (Android TV or Google TV)​
  1. Press the Home button.
  2. Open the Google Play Store or App Finder.
  3. Search for Apple TV.
  4. Install the app.
  5. Launch it and sign in.
Vizio SmartCast TV​
  • No installation needed! Vizio SmartCast TVs have the Apple TV app pre-installed.
  • Just open the app from the home screen and log in.
TCL / Hisense (Roku or Google TV)​
For Roku models:
  1. Press Home > Go to Streaming Channels.
  2. Select Search Channels.
  3. Type “Apple TV” and click Add Channel.
  4. Open and sign in.
For Google TV models:
  1. Use the App Store to find Apple TV.
  2. Click Install.
  3. Open the app and log in.
What If My Smart TV Doesn’t Support the Apple TV App?​
If your TV doesn’t support the Apple TV app directly, here are some workarounds:
Option 1: Use a Streaming Device​
DeviceCompatible with Apple TV?
Apple TV 4K✅ Yes (best performance)
Roku✅ Yes
Amazon Fire Stick✅ Yes
Google Chromecast✅ Yes (via Apple TV app)
Xbox / PlayStation✅ Yes
Option 2: Use AirPlay (Screen Mirroring)​
If you have an iPhone, iPad, or Mac, and your TV supports AirPlay 2, you can stream Apple TV content directly:
  1. Make sure your TV and iPhone/Mac are on the same Wi-Fi.
  2. Open the Apple TV app on your iPhone or Mac.
  3. Tap the AirPlay icon and select your TV.
💡 Tip: Look for the “Works with Apple AirPlay” logo on your TV box or manual.
How to Sign In to Apple TV on Smart TV?​
You can sign in using two methods:
Option 1: Apple ID & Password​
  • Just enter your Apple ID credentials using your remote.
Option 2: Activation Code​
  1. Choose Sign in with activation code on your TV.
  2. Visit https://activate.apple.com on your phone or computer.
  3. Enter the code shown on your TV.
Frequently Asked Questions​
Q1: Is the Apple TV app free on Smart TVs?​
A: Yes, the app is free to download, but you’ll need a paid Apple TV+ subscription to watch exclusive content.
Q2: What Smart TVs support Apple TV?​
A: Most 2018+ models from Samsung, LG, Sony, Vizio, TCL, and Hisense support the app.
Q3: Can I use Apple TV without an Apple device?​
A: Absolutely. As long as you have an Apple ID and a compatible Smart TV, you don’t need an iPhone or Mac.
Q4: Why can't I find the Apple TV app on my Smart TV?​
A: Your TV may be too old or in a region where Apple TV isn’t supported. You can try using a Roku, Fire Stick, or AirPlay as a workaround.
Final Thoughts​
Getting the Apple TV app on a Smart TV is easier than ever in 2024. If your TV is relatively recent (2018+), you should be able to download the app directly from your app store and start streaming.
ScenarioSolution
TV supports Apple TV appInstall directly from app store
Older or unsupported TVUse Roku, Fire Stick, or AirPlay
No Apple IDCreate one free at apple.com
Related Reading:
How to Reset Apple TV Remote: A Comprehensive Guide
How to Watch MLS on Apple TV: Your Complete Guide
