Netflix has become a must-have streaming app in every home — and the good news is, most Smart TVs make it incredibly easy to get started. Whether you have a Samsung, LG, Sony, Vizio, or TCL, this guide will show you exactly how to get Netflix on your Smart TV and start streaming in minutes.
Yes, Netflix comes pre-installed on many Smart TVs and is available for download on most major brands, including:
If your TV is from 2013 or later, chances are Netflix is supported.
The method depends on your TV brand. Use the guide below based on your Smart TV model:
If using Roku TV:
If using Google TV:
If Netflix isn’t showing up or isn’t supported, try these solutions:
Connect one of these to your TV’s HDMI port:
If your TV doesn’t have the app:
After installing Netflix:
A: The app is free to download, but you need a paid subscription to watch content.
A: Your TV might be outdated or located in a region where Netflix isn’t available. Try using a streaming stick like Roku or Fire TV.
A: Yes, if your TV supports 4K UHD and you’re on the Netflix Premium plan. Also, ensure you have a fast internet connection (at least 25 Mbps).
Getting Netflix on your Smart TV is simple — whether it comes pre-installed or needs to be downloaded, most users can start streaming in just a few clicks. If your TV doesn’t support it, there are plenty of reliable options using external devices or screen casting.
Related Reading:
Netflix Won't Play on Vizio Smart TV, Quick Fix
Is Netflix Available on All Smart TVs?
- Samsung (Tizen OS)
- LG (webOS)
- Sony (Google TV / Android TV)
- Vizio (SmartCast)
- TCL (Roku TV / Google TV)
- Hisense, Panasonic, Philips, and more
How to Get Netflix on a Smart TV: Step-by-Step Instructions
Samsung Smart TV (Tizen OS)
- Press the Home button on your remote.
- Go to Apps.
- If Netflix is already installed, just select it.
- If not, use the Search icon (top right) and type “Netflix.”
- Select the Netflix app, then click Install.
- Open the app and sign in with your Netflix account.
Tip: On some remotes, there's a dedicated Netflix button — press it to launch the app instantly.
LG Smart TV (webOS)
- Press the Home button.
- Navigate to the LG Content Store.
- Type “Netflix” in the search bar.
- Select and install the Netflix app.
- Launch the app and log in to start watching.
Most LG TVs from 2014+ support Netflix in 4K HDR.
Sony Smart TV (Android TV / Google TV)
- Go to Apps > Google Play Store.
- Search for Netflix.
- Select the app and click Install.
- Open the app and sign in.
You may need to update your TV software to see Netflix in the Play Store.
Vizio Smart TV (SmartCast)
- Vizio SmartCast TVs come with Netflix pre-installed.
- Just press the V or Home button, navigate to Netflix, and launch it.
- Sign in with your Netflix credentials.
No installation required on newer Vizio models.
TCL or Hisense Smart TV
If using Roku TV:
- Go to Streaming Channels > Search Channels.
- Search for Netflix, then click Add Channel.
- Launch and log in.
If using Google TV:
- Go to the Google Play Store.
- Search and install Netflix.
Can’t Find Netflix on Your Smart TV?
Option 1: Use a Streaming Device
Device | Supports Netflix? |
Roku | ![]() |
Amazon Fire TV | ![]() |
Google Chromecast | ![]() |
Apple TV | ![]() |
Game consoles | ![]() |
Once connected, install Netflix from the device's app store and sign in.
Option 2: Use Screen Mirroring or Casting
- Open Netflix on your phone or tablet.
- Tap the Cast icon (top right).
- Select your Smart TV from the list.
- The video will play on your TV.
Your TV and phone must be connected to the same Wi-Fi network.
How to Sign In to Netflix on Smart TV
- Open the app.
- Choose “Sign In”.
- Enter your email and password using the on-screen keyboard.
- Alternatively, visit netflix.com/tv8 on your phone/computer and enter the code shown on your TV.
Frequently Asked Questions
Q: Is Netflix free on Smart TVs?
Q: Why can’t I find Netflix on my Smart TV?
Q: Can I watch Netflix in 4K on my Smart TV?
Setup Method | Recommended For |
Native Netflix App | Most TVs made after 2014 |
Roku / Fire TV Stick | Older TVs or unsupported models |
AirPlay / Chromecast | Streaming from mobile devices |
Related Reading:
