If your Samsung Smart TV is acting up—whether it’s freezing, running slow, or the apps aren’t working properly—resetting your TV might be the simplest and most effective fix. This guide will walk you through how to reset a Samsung Smart TV using both standard and advanced methods, including when your remote isn't working.
This works for most Samsung models from 2016 and newer.
Step-by-Step:
If you just want to fix a temporary issue without erasing your settings:
If you lost your remote, you can still reset your Samsung TV:
Alternatively, you can use the SmartThings app on your smartphone as a remote control if both devices are on the same Wi-Fi network.
If your Wi-Fi won’t connect, try this first:
By following this guide, you can troubleshoot most problems and restore your Samsung Smart TV to peak performance.
Related Reading:
How to Factory Reset Samsung Smart TV: Complete Step-by-Step Guide
Why Reset Your Samsung Smart TV?
- Fix app crashes and lagging performance
- Clear temporary glitches or settings conflicts
- Remove custom settings or network problems
- Restore factory settings before selling or gifting the TV
Method 1: How to Factory Reset a Samsung Smart TV (With Remote)
Step-by-Step:
- Press the Home button on your remote.
- Go to Settings > General > Reset.
On newer models, go to Settings > Support > Device Care > Self Diagnosis > Reset. - Enter your PIN (default is 0000 if you haven’t changed it).
- Select Yes to confirm.
- The TV will restart automatically and return to factory settings.
Method 2: Soft Reset (Quick Restart Without Data Loss)
- Hold the Power button on your remote for about 5 seconds, or until the TV powers off and back on.
- Wait a moment as the system refreshes.
This method is helpful for freezing or unresponsive apps and won’t delete any user data.
Method 3: Reset Without Remote (Using Buttons on TV)
- Locate the Power or Control button on the bottom or back of the TV.
- Long press the button (or navigate using the on-screen menu with it) to access Settings.
- Use the volume and channel buttons to select and confirm options.
Extra Tip: Resetting Network Settings Only
- Press Home > go to Settings > General > Network > Reset Network
- Confirm the action.
- Reconnect your Wi-Fi with the correct password.
What Happens When You Reset a Samsung Smart TV?
Affects | Description |
Picture & Sound Settings | Reset to default |
Apps | Removed (you’ll need to reinstall them) |
Wi-Fi Settings | Erased (must reconnect manually) |
Samsung Account | Logged out |
Remote Pairing | May need to re-pair Bluetooth remotes |
Summary: How to Reset a Samsung Smart TV
Reset Type | When to Use |
Factory Reset | Major issues, reselling, full reset |
Soft Reset | Minor glitches or app lag |
Network Reset | Wi-Fi problems or connectivity issues |
Without Remote | Lost remote or unresponsive device |
Related Reading:
