How to set up Fire TV Cube with AV receiver?
Jemma
It's easy to set up Fire TV Cube with AV receiver. First, connect the AV receiver to the TV with an HDMI cable, and then connect the Fire TV Cube to the AV receiver with another HDMI cable (if you want 4K video, be sure to use the 4K port on the AV receiver). Finally, use the remote control to adjust the display and sound settings.
Graceli
How to set up Fire TV Cube with AV receiver? Follow these steps:
First, connect the AV receiver to the TV.
Plug a rated high-speed HDMI cable into the HDMI input that supports arc on the TV, and connect the other end to the back of the AV receiver.
Now, connect another HDMI cable to connect the Fire TV Cube and the AV receiver.
Thskhdsds
Thanks for your help! I will try!
