How to Turn Dangbei Mars Pro to Bluetooth Speaker Mode?
Ray
A good projector is not just for watching movies, but also a Bluetooth speaker. The projector working in the Bluetooth speaker mode can turn off the optical engine, reduce consumption and prolong the service life of the projector. So how does the Dangbei Mars Pro projector convert into Bluetooth speaker mode? There are detailed guides for you.
As a 4K laser home projector with cinematic Dolby Audio, Dangbei Mars Pro projector not only provides vivid images but also an immersive stereo sound experience. People can enjoy movies with its big screen and stunning viewing of pictures in projection mode, or just enjoy music with the Bluetooth Speaker mode. When switching to Bluetooth Speaker mode, Dangbei Mars Pro projector can be connected to usual digital devices such as phones, computers. It only takes several steps to turn Dangbei Mars Pro into Bluetooth speaker mode.
How to Turn Dangbei Mars Pro to Bluetooth Speaker Mode and connect to phone?​
1. First, short press the Power key on the remote control, the screen will show different modes, then select the Bluetooth Speaker mode. Now Dangbei Mars Pro is entering to the Bluetooth speaker mode and waiting for connecting.
2. Then, turn on the Bluetooth connection settings on your device that is ready to connect with Dangbei Mars Pro. Take the phone as an example, find the Bluetooth name of your Dangbei Mars Pro on the searching list and click to connect it.
3. As expected, a beep sound of "Bluetooth connection is successful" should be heard, and your phone and the Dangbei Mars Pro projector are successfully connected.
After turning Dangbei Mars Pro projector into Bluetooth mode, you can play music with the Dolby Audio sound effect. If you want to exit the Bluetooth Speaker mode, just short press the remote control Power key again.
Felia
Connect the phone to the projector under Bluetooth mode and then play your phone music but get a Dolby audio effect, good idea!
