How to turn off motion smoothing on VIZIO TV?
kihndg
I want to turn off motion smoothing, but I can't seem to do it! Does Vizio have smooth motion permanently enabled? Any help?
LLLisa
Open the settings menu on your Vizio TV, select "Pictures", and switch to the "Advanced Pictures" tab.
Here you can set different levels for the Smooth Motion Effect, such as adjusting how much interpolation and motion blur is applied. You can disable it completely by setting it to "Off".
Barton7
On the V Series it's under Picture, then Advanced, then Film Mode off. The M series has replaced that set now, but the menu path barely changed. Also check that the input isn't stuck in a preset like "Vivid.
