How to uninstall apps on Samsung Smart TV?
Kevinlll
Uninstalling apps you no longer need can free up memory space on your TV. It only takes a simple walk to uninstall apps from your Samsung TV.
First, press the Home button to open the TV's Home menu.
Then navigate to the application interface and select the settings icon in the upper right corner.
Next, just select the app you want to delete. Finally, select Delete and select Delete again to confirm. The app is now uninstalled from your TV.
