waterloo
How to use Epson projector for wireless projection on iPhone / iPad ? Share a tutorial for everyone today.
First, the connection (we take EPSON EB 1975W , iOS 9.3.5 operating system, iProjection 2.2.0 application software as an example)
iPhone / iPad device preparation:
1.1 iPhone / iPad must use iOS 4.3 or later operating system;
1.2 iPhone / iPad “Wireless LAN” function has been turned on, and it has been established with the wireless router The connection of
1.3 ; iPhone / iPad has installed "EPSON iProjection" application software (you can download the software through the "App Store" or "iTunes Store").
Preparation of the projector:
2.1 It is recommended that you use a wireless network card dedicated to EPSON (if the projector is not included in the package, it needs to be purchased separately). Install the dedicated wireless network card on the correct interface (please refer to the user guide on the CD-ROM of the projector), and the status of the indicator on the wireless network card is normal after the projector is turned on (the green indicator is always on or blinking);
2.2 If you have not Purchase EPSON dedicated wireless network card or your projector does not support the use of wireless network card, and your projector has a LAN interface (RJ45 interface), you can also use a network cable to connect the projector's LAN interface with the wireless router's LAN interface ( Note: Do not connect to the WAN interface of the router).
Procedure
The projector installed where EPSON a dedicated NIC:
1.1 on the projector by "Menu" button on the remote control to enter the menu, find and enter the "Network Settings" menu, enter the "wireless LAN" tab;
1.2 Select "Advanced" for "Connection Mode", and change "SSID" to the same SSID as the wireless router (namely the name of the router in the network, note: the capitalization of English letters must be the same), in "IP Settings" Set "DHCP" to "On" (you can also set DHCP to off according to actual needs and manually assign the projector's IP address)
1.3 If the wireless router has encryption, you need to enter the "Security" tab in the projector's network configuration menu, select the encryption type and enter the correct password
When the projector is connected to the wireless router via a network cable:
Enter the menu through the "Menu" button on the projector remote control, find and enter the "Network Configuration" menu, and enter the "Wired LAN" tab. Set "DHCP" to "On" in "IP Settings" and the router will assign an IP address to the projector. Of course, you can also set DHCP to off according to actual needs, and manually assign the projector's IP address;
Run the EPSON iProjection application software on the iPhone / iPad.
The software will search for the name of the target projector, select it and click "Connect" . The software will prompt "Connect to the projector?" And click "OK". After successful connection, the software will prompt "Connection successful.", Click "OK";
After the EPSON iProjection software is properly connected to the projector, click the option in the upper left corner of the software interface. At this time, you can use the options in the drop-down menu to project and control
Note: EPSON iProjection application software can only project images, documents and webpages in fixed formats, and cannot fully reproduce and project iPhone / iPad screen content.
Procedure
