loughborough
The plug that controls my digi box is buried inside a cupboard. The plug sending power to the. TV is a bit difficult to get at, both are now connected to a smart plug
Now I understand that if not turned off at the plug that the box is still using energy. So my question is: if I use a smart plug to turn off the plugs when not in use will save that energy.
Do you really save much energy ?
