Introduction of Laser TV And Its Features
reality
What is laser TV? Laser TV is a new type of display product that combines innovative technologies in three key areas. Combining DLP technology, network connection and intelligent application operating system of laser light source. Combined with these three technologies, a laser TV allows users to display large amounts of multimedia content on a screen or almost any surface, usually larger than 100 inches.
Laser fluorescent light source - laser fluorescent light source has a long service life compared with other traditional light sources. It also has an instant on/off function, so there is no need to heat or cool the system when the power is on or off.
Portability - traditional big-screen TVS are bulky and not easily moved or transported. Laser TV using DLP technology, can be moved from room to room, very convenient.
Flexible display size - while traditional TVS have a fixed display size, laser TVS have a flexible display size, allowing you to zoom in and out of the display surface and display images from the traditional 80 to 100 inches to 140 inches. Customers can then customize the display for different purposes.
Easy to install - with ultra-short focus projection optics, consumers can display stunning content simply by placing mobile devices a few feet away from the display surface
Optional screen - no need for a fixed screen to display bright pictures and videos at the same size on most surfaces. If necessary, add a curtain to block ambient light, which will increase the brightness reflected onto the curtain.
