LG 4K Projector HU710PW Review: Laser and Dual LED Hybrid Light Source
Mialulu
LG released the 4K projector HU710PW with a laser light source and dual LED light sources. Although the projector is small in size, its high power and three light sources allow it to project a maximum screen of 300 inches. So what about this $2825 laser projector HU710PW review? Is it worth buying?
Laser & Dual LED Hybrid Light Source
The HU710PW projector is also a member of the "LGCineBeam" series. It uses a blue laser and a red/blue LED hybrid light as the light source, and reproduces vivid green through blue laser + green phosphor to achieve brightness and color performance suitable for 4K image quality. Compared with the traditional DLP color wheel method, the color performance of HU710PW is better and purer.
Image Performance
The projection resolution is 3,840x2,160, the projection screen size is 40 to 300 inches, the brightness is 2,000ANSI streams, and the contrast ratio is 2,000,000:1. The HDR of the HU710PW Projector supports the most popular HDR10, as well as "HLG" commonly used in TV broadcasting and "HGiG" compatibility which sets the standard for stable display of HDR-compatible game content.
Screen Adjustment
The LG 4K Projector HU710PW projector supports a lens shift of up to 24% in the horizontal direction and 60% in the vertical direction, and the screen layout can be adjusted even after installation. It supports up to 1.6x zoom and can correct a total of 15 points of distortion. 3 rows for the top, center and bottom, and 5 rows for the bottom. Even if the projected image is distorted due to unevenness or angle of the wall surface, the image can be displayed in a stable shape.
Connections
LG 4K Projector HU710PW has rich interfaces: HDMI2.1x1, HDMI2.0x2, which support eARC, CEC, ALLM connections. And it is equipped with optical digital output, USB port and LAN terminal, and it also supports Wi-Fi and Bluetooth connection.
Operating System
The operating system of LG 4K Projector HU710PW is webOS6.0 developed by LG. Like the smart system built into LG TVs, you can enjoy YouTube, Netflix, Amazon Prime Video, Disney+, and more using your internet browser or VOD app.
Dual Speakers
The LG 4K Projector HU710PW has built-in speakers with an output of 5W+5W. In addition to being able to connect wirelessly with Bluetooth headphones, you can also build a surround environment with built-in speakers and external speakers. Since it is compatible with Dolby Atmos, it enables realistic stereo sound. You can also connect the projector to a mobile device via Bluetooth to use the projector as a Bluetooth speaker.
LG 4K Projector HU710PW with advanced laser and dual LED light source, produces high-quality images. The high contrast and lumens are also competitive points on the market. Have you bought it? Welcome to share more reviews of it!
Wyatt21
Did anyone ever measure the actual color gamut on this? LG claims better purity than a color wheel, but I'd want to see DCI-P3 numbers before believing it at this price.
