LG CineBeam HU710PW Review: Is This Full-Feature Hybrid Laser Projector Worth It?
WWGHIAFTC
First Impressions​
The new hybrid light engine in the HU710 employs a blue laser diode with a static, solid-state phosphor chip together with a pair of LEDs modules, one red and one blue. The laser and phosphor chip are used to generate the green primary, while the red and blue LEDs are used directly for reproducing those colors; the HU710 does not use a color wheel, though individual colors must still be presented sequentially to the single DLP chip. During my time with the projector I thankfully did not experience any rainbows in any content. The projector has rated ANSI lumens of 2,000, which makes it considerably less bright than the 2,700-lumen all-laser HU810. But it offers very nearly the same rated color gamut at 94% DCI-P3.
This projector offers UHD resolution of 3840x2160 via use of the Texas Instruments DLP 0.47-inch XPR (Expanded Pixel Resolution) chipset to produce 8.3 million discrete pixels. This chipset takes a DMD with native 1920x1080 resolution and applies a four-phase pixel shift to reproduce the full 3840x2160 resolution in each frame of UHD video. So, while it's technically not a true native 4K projector, with all else being equal the 4K images produced by this projector are essentially indistinguishable from a native 4K image in typical viewing conditions.
LG CineBeam HU710PW​
$1999​
Home Cinema​
Remote Control, Power Cord, User Manual, HDMI Cable​
Highlight
Screen Size: Up to 300 inches
Resolution: 4K (3840 x 2160)
Brightness: 2,000 ANSI Lumens
Lens Adjustment: Lens Shift & Zoom
Warping Options: 4/9/15 Point Warping
Light Source: Hybrid (1 Laser + 2 LEDs)
Contrast Ratio: 2,000,000:1
Color Gamut: DCI-P3 94%
HDR Support: HDR 10 with Dynamic Tone Mapping
Motion Technology: TruMotion
Filmmaker Mode: Yes
IRIS Mode: Adaptive for natural lighting
Adaptive Contrasts: Yes
56.25 Inches - 150 Inches​
5.9 Inches - 21.25 Inches​
2000000:1​
3840 x 2160​
3840 x 2160​
2200 Lumen​
DLP​
Triple Laser Tech, HDR10​
Viewing Experience
The HU710 projector offers a wide array of picture modes, with nine options for SDR and seven for HDR. While it provides flexibility, the initial out-of-the-box performance is marked by a significant green bias across most modes, particularly in the Brightest settings, making them less usable. The most accurate and visually pleasing modes for SDR are Cinema, Filmmaker Mode, and Expert Bright, while Cinema Home stands out for HDR. However, all modes exhibit a deficiency in red, affecting overall color accuracy.
For optimal performance, calibration is recommended, as the projector includes extensive white balance adjustments and a comprehensive color management system. Users who take the time to calibrate can expect excellent results, although the HDR white balance controls may have limited range compared to LG's TVs. Overall, while the HU710 shows potential and offers advanced features, it requires calibration to achieve its best performance.
H.265 (HEVC)​
30000 Hours​
10 watts​
Wireless (WiFi, Bluetooth) Wired (USB, HDMI)​
Hardware Connectivity​
HDMI, USB 2.0​
Television, Gaming Console, Laptop, Smartphone, Tablet​
Triple Laser Tech, 107% BT.2020, 80”-150” Image Size, Dolby Atmos, 4K UHD, Active 3D, HDR 10, HDMI ARC, Android TV 10.0, MEMC, 8-Point Keystone Correction, Eletric Focus, Ultra Short Throw​
20.5"L x 13"W x 6"H​
This projector offers a robust set of features, including a variety of input/output options such as optical digital audio out, a LAN port, and multiple USB 2.0 ports for versatile media playback. The inclusion of webOS 6.0 enhances the user experience with a smooth interface and access to popular streaming services like Netflix, Prime Video, Disney+, YouTube, and AppleTV. The ability to easily mirror content from mobile devices using AirPlay2 and MiraCast adds significant value, especially for those seeking access to additional streaming platforms. While the absence of certain apps like HBO Max and Hulu may disappoint some users, the projector's overall performance and functionality, including support for 4K playback, make it a compelling choice for home entertainment.
User Feedback​
• Easy setup, especially for ultra-short throw (UST) configuration
• Stunning 4K UHD image quality with true and realistic colors
• Minimal software adjustments needed for optimal performance
• Flexibility to customize with a streaming device of choice
• Excellent compatibility with various media sources like NVIDIA TV Shield
• Great sound quality, especially when paired with an external sound system
• Impressive performance with 4K UHD streaming from major services
• Difficult to set the keystone adjustment
• Picture quality may not meet expectations without proper setup
• Limited control over brightness settings
• Requires a special remote for viewing 3D content
• Lacks Dolby Vision support
The Casiris A6 ultra short throw projector stands out as an impressive option for home theater enthusiasts, delivering stunning 4K UHD visuals and solid sound quality. While there are some drawbacks regarding keystone adjustments and brightness control, the projector's overall performance, flexibility, and ease of setup make it a strong contender in the budget projector market. For those looking to enhance their viewing experience, pairing it with an ALR screen and a quality sound system can elevate the home theater experience to new heights.
