Magicsee N6 Plus Android 9 TV Box Review
Gene
This is the Magicsee N6 Plus TV box review. The specs is down below.
Specification
GeneralBrand: Magicsee
Model: N6 Plus
Type: TV Box
Hardware
OS: Android 9.0
CPU: Amlogic S922X
Quad-core ARM Cortex-A73
Dual-core ARM Cortex-A53
GPU: Mali TM-G52 MP6 (6EE)
RAM: DDR4 4GB
Memory size: eMMC flash 32GB/64G
Communication
Wi-Fi: 2.4GHz/5GHz IEEE 802.11a/b/g/n/ac 2*2 MIMO
Bluetooth: BT4.1
Ethernet: 10/100/1000M
Media
[email protected]
[email protected]@60fps
[email protected]
[email protected]@30fps
Interface
USB port: 1 x USB2.0 OTG + 2 x USB3.0
SPDIF digital audio x 1
HDMI 2.1 x1
A/V OUT x 1
Ethenet x 1
TF card slot x 1
Other Features
Software Extension: Support Google Play & APK install
Image browser: Support JPG, JPEG, BMP, GIF, PNG, JFIF…etc photo format
LED Display: Support
Power
Power Supply: 12V1.5A DC
Dimensions&Weight
Package weight: 0.7kg
Package size (L x W x H): 18.5 x 13.5 x 8.0cm
Package Contents
TV BOX x 1
HD Cable x 1
Remote control x 1
User manual x 1
Power adapter x 1
dwuw
the small green or blue square on the box surface which makes it feel like mosaic. It drives me crazy, I'm not comfortable with its design
