EmmaStone
Many articles have told us that the higher brightness, the better the projector is. And as we all know, projectors with higher brightness cost more money. So is it reasonable? Today I would like to bring you the most intuitive and different feelings of brightness!
Today we are comparing three smart projectors with 300ANSI lumens, 800ANSI lumens and Dangbei Super Projector F1 with a brightness of 1400ANSI lumens .
First, we adjusted the brightness mode to a unified highlight mode.
The three projectors open the main page of the Dangbei market at the same time . It is obvious that the brightness of the Dangbei super projector F1 is the highest when the light is turned on.
The 1400ANSI lumens performance of Dangbei Super Projector F1 when the lights are off is also outstanding.
The brightness and resolution of the projector are related to a certain extent. The following are the 4K resolution test charts of the three projectors .
It can be seen from the test chart that the projector resolution of 300 ANSI lumens is the lowest, followed by 800 ANSI lumens, and the best is the F11400 ANSI lumens projector.
The above is the difference between the actual measurement of 300ANSI lumens and 1400ANSI lumens. I believe everyone can see it at a glance! The gap between hundreds of lumens is still huge!
