Mijia Laser Projector Full HD 4K ALPD 3.0 5000 Lumens
This is the world's first ultra-short projector with advanced laser display ( ALPD ) technology, which delivers up to 150 inches of full HD quality images in 50 centimeters, with product life up to 25,000 hours. To achieve user-friendly design goals, the high-tech product uses a compact, minimalist "box" design language, and carefully maintained the host and Bluetooth remote control design style consistency. In any corner of the room control the host, voice assistant quickly find programs and other interactive ways for the user to bring a new movie viewing experience.
Main Features:
● Ultra short projection distance: the laser projector itself only needs to be placed 50cm away from the wall in order to deliver 150 inch screen projection
● Providing up to 150 inch TV experience: theater-class laser projection TV
● Ultra-short focal lens: the projector screen can be placed in the TV cabinet with the size adjusted to fit in your screen
● Fine tuning images itself: you don't need to manually focus the lens as it fine tunes itself
● 5000 lumens: utilizes ALPD 3.0 laser light source tech developed by apporonics, for high resolution of the projected image
● The remote control is powered by 2 x AAA battery ( not included )
●Tips: the default language is Chinese. It can be partially changed to English after installing the APP attached. We take out of the battery for the remote from the original package to ensure the safe international shipping. Please keep calm if you find the original package is not perfectly intact
Basic information:
Optical parameter
Display: 0.47 inch DMD
Resolution: Full HD ( 1920 x 1080 )
Support resolution: 4K
Light source: ALPD 3.0
Brightness: 5000 lumens
Light mode: highlight, movie, normal
Auto mode: save power, eye protect
Brightness uniformity: JBMA more than 80 percent
Color gamut: NTSC 80 - 85 percent
Central contrast: 3000 : 1
Color temperature: standard, cold color, warm color
Projection parameter
Throw ratio: 0.233 : 1
Best project distance: 150 inch
System parameter
CPU: T968 Cortex-A53 4-core 1.8GHz / 64bit
RAM: 2GB DDR3
ROM: 16GB eMMC Flash
System function
Operate OS: MIUI TV
Support Android: Android 6.0 and above
WiFi: dual-band 2.4GHz + 5GHz
Bluetooth: V4.0
HDR: support
keystone correction: four corners, eight corners
Focus: power focus
3D: support
Other parameter
Voltage: 200 - 240V at 50 / 60Hz
Sound: DOLBY
External speaker: support
Speaker: full frequency speaker x 2 + high frequency speaker x 1
Remote control: Bluetooth, voice
Connection: Ethernet x 1, SPDIF x 1, audio out x 1, AV 3.5 x 1, USB 3.0 x 1, ARC x 1, HDMI 2.0 x 2
Voice: less than 32dB ( at 25 Deg.C )
Power consume: 250W ( max )
