Unboxing Experience
- 1.1.1 NICPOW Mini Projector:
- 1.1.2 PURSHE Mini Bluetooth Projector:
- 1.1.3 VISSPL Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 NICPOW Mini Projector:
- 1.3.2 PURSHE Mini Bluetooth Projector:
- 1.3.3 VISSPL Mini Projector:
- 1.4 Features
1.5
- 1.5.1 NICPOW Mini Projector:
- 1.5.2 PURSHE Mini Bluetooth Projector:
- 1.5.3 VISSPL Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
| Parameter | NICPOW Mini Projector | PURSHE Mini Bluetooth Projector | VISSPL Mini Projector |
Picture | |||
Reference Price | $49.99 | $48.99 | $69.99 |
Recommended Uses | Outdoor or indoor | Home Cinema | Home Cinema |
Built-In Media | 1 x NICPOW Projector,1 x HDMI Cable 1 x 3 inches (approx. 2.5 x 7.6 cm) AV Cable,1 x Power Supply ,1 x User Manual,1 x Remote Control, 1 x Tripod | Remote Control | User Manual, Power Cord, Projector Lens Cover, Remote, HDMI Cable |
Highlight | Resolution: 1920x1080P (native 1280x720P) Projection Distance: 3.3 to 21.8 feet (optimal 6.5 to 8.2 feet) Viewing Size: 32'' to 240'' Color Contrast: 6000:1 Brightness: 7500 lux Aspect Ratio: 4:3 / 16:9 Keystone Correction: ±15° Lamp Life: 65,000 hours Audio: 2x3W HiFi stereo speakers with SRS sound system Connectivity: HDMI, 2xUSB, AV, AUDIO (AV and HDMI cables included) Compatibility: Smartphones, TV sticks, game consoles, PCs, tablets, laptops, DVD players, USB sticks Warranty: 36 months replacement support, lifetime technical support | Product Type: Portable Mini Projector Dimensions: 7 x 5 x 2.5 inches Weight: Palm-sized, easy to carry Resolution: 1080P Full HD Brightness: Superior to larger projectors Color Technology: Advanced color reproduction Bluetooth Version: 5.1 for wireless audio Audio Output: Built-in 3W stereo speakers Cooling System: Advanced fan cooling, extends bulb life to 50,000 hours Setup: Plug and play with multiple devices (Smartphone, Laptop, etc.) Aux Port: Yes, for external speakers Usage Scenarios: Indoor/outdoor movie nights, camping, gatherings Screen Size Capability: Up to 200 inches | Size: 6.1 x 5.08 x 2.4 inches Weight: 1.1 lb Resolution: Full HD 1080P Screen Size: 35-160 inches Keystone Correction: ±15° Speaker: Built-in HiFi speaker Input Ports: HDMI, USB, AV, Audio Lamp Life: Over 55,000 hours Cooling Technology: 50% noise reduction Technical Support: Lifetime support Eye Protection: Minimizes blue and direct light impact |
Unboxing Experience
The projector boasts a compact design, roughly the size of an open hand, which makes it portable and easy to transport for various uses like outdoor movie nights and camping trips. While it may not fit the "mini" label as some expect, it does come with a small tripod and a carry handle, allowing for some level of convenience when moving between locations. Overall, the build quality feels satisfactory considering its low price point, although it does have a somewhat top-heavy design that affects stability when placed on uneven surfaces.PURSHE Mini Bluetooth Projector:
The projector boasts a sleek and compact design, which I found appealing. Its small and lightweight construction means I can easily place it on a shelf, table, or even carry it around for outdoor movie nights. The build feels sturdy despite its size, giving it a durable feel that inspires confidence in its longevity. Overall, I appreciate that it combines functionality with a modern aesthetic, making it a great addition to any room or outdoor setting.VISSPL Mini Projector:
The VISSPL 4K Supported Video Projector impresses with its compact design, making it highly portable and easy to store. Its sleek and modern aesthetic fits seamlessly into any environment, whether it’s a classroom, living room, or outdoor setting. The projector feels durable, ensuring it can withstand frequent movement without showing signs of wear. The overall appearance conveys a sense of reliability and functionality, appealing to both casual users and professionals alike.Display
Screen Size | 32 Inches - 1E+2 Inches | 32 Inches - 2E+2 Inches | 35 Inches - 160 Inches |
Throw Distance | 3.3 Feet - 22.9 Feet | N/A - 12 Feet | 1 Meters - 4.5 Meters |
Contrast Ratio | 6000: 1 | 6000:1 | 10000:1 |
Maximum Resolution | 1920 x 1080 pixels | 1920*1080 Pixels | 1920 x 1080 |
Native Resolution | 1280 x 720 | 1920 x 1080 | 1920 x 1080 |
Brightness | 7500 lumen | 9500 | - |
Viewing Experience
The image quality is surprisingly good for the price, with many users reporting a clear display that approaches 720p resolution, even at larger sizes of up to 240 inches. Brightness levels generally perform better in dark environments, rated around 8 out of 10 in low light and slightly less in brighter conditions. While some complain about the sound quality being average, the projector can still deliver an enjoyable viewing experience for casual uses like movie nights or gaming, especially when paired with external speakers.PURSHE Mini Bluetooth Projector:
The viewing experience exceeded my expectations, with vibrant colors and sharp images that really brought my movies and games to life. I was particularly impressed with its performance even in rooms with some ambient light; however, it truly shines in darker environments. The projector supports a maximum display size of 300 inches, which added to the cinematic feel during family movie nights. The included 120-inch projector screen was a thoughtful touch, enhancing the overall experience without needing additional purchases.VISSPL Mini Projector:
The viewing experience provided by this projector is nothing short of spectacular. The image quality is sharp, bright, and vibrant, with a maximum brightness of 15,000 lumens that makes it suitable for both dark and well-lit environments. I love how I can adjust the image size from a modest setup to a whopping 400 inches diagonally, making it perfect for movie nights or presentations. The sound quality is decent for a projector of this size, and with the option to connect to Bluetooth speakers, I can easily enhance the audio experience.Features
Other Features | Built-In Speaker | Bluetooth, Built-in speaker, HDMI and USB connectivity | Zoom 100%-50%, Built-in Hi-Fi Speaker, Mini and Portable, Tripod Included, Full HD 1080P |
Video Encoding | AVC | AVC | AVC |
Lamp Wattage | 75 Watts | 3 Watts | 6E+1 Watts |
LightSource Life | 65000 Hours | 5000 Hours | 60000 Hours |
Controller Type | Remote Control | Remote Control | Button Control |
Connectivity Technology | MHL, USB, HDMI, VGA | Bluetooth, USB, HDMI, 3.5mm Jack | HDMI |
Compatible Devices | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet | Smartphone, Laptop, TV Stick, PS4, DVD player, Tablet | Laptop, PS5, External Speakers, Smartphone, TV Stick |
Wattage | 50 watts | 3 watts | 60 watts |
Mount Type | Wall, ceiling, vertical, desktop mount | Ceiling/floor/Tabletop/Tripod/Wall Mount | Tripod Mount |
L x W x H | 8.66"L x 7.09"W x 3.94"H | 7"L x 5"W x 2.5"H | 6.1"L x 5.08"W x 2.4"H |
Setting up the projector is straightforward and user-friendly. It features a single HDMI port, making it simple to connect devices like laptops, gaming consoles, and streaming devices. The projector natively accepts HDMI signals, allowing for quick plug-and-play functionality. Keystone and focus adjustments are intuitive, contributing to a hassle-free setup experience. However, potential users should be aware that they will need additional cables—like HDMI adapters for phones—as these are not included in the package.PURSHE Mini Bluetooth Projector:
Setting up the projector was a breeze, taking me less than 10 minutes right out of the box. I appreciated the clear instructions that guided me through the process. The numerous connectivity options—HDMI, VGA, USB, and Bluetooth—allowed me to connect various devices, including my smartphone, laptop, and streaming devices, without any hassle. The Wi-Fi setup was equally straightforward, and I was easily able to link it to my home network, making it convenient for streaming content.VISSPL Mini Projector:
Setting up the VISSPL projector is a breeze. I was able to connect my laptop using the HDMI cable included with the package, and the wireless connectivity options for my iOS devices and TV Stick worked seamlessly. The electric keystone correction feature is an absolute game changer, allowing me to adjust the image alignment with just a touch of a button. Within minutes, I was ready to project, and the intuitive interface meant I didn’t even have to glance at the manual to get started.Conclusion
Pros:• Impressive display quality for the price.
• Easy to set up and connect to various devices.
• Portable design with decent brightness in dark conditions.
• Good customer service experience noted by multiple users.
• Built-in speaker quality is subpar and may require external speakers.
• Limited keystone adjustment can affect image alignment.
• Misleading "mini" label; it's larger than expected.
• Short power cord and missing accessories like A/V cables in some packages.
For just around $50, this projector delivers exceptional value for those looking for a budget-friendly option. While it may not replace high-end projectors in terms of features and quality, it performs admirably for casual viewing and gaming experiences. Users should manage their expectations regarding sound quality and size but can feel confident in their purchase, especially if they require a device for occasional use rather than professional settings. In summary, I would recommend this projector for anyone looking for an affordable solution that meets basic projection needs without breaking the bank.
Pros:• Excellent picture quality with vibrant colors
• Lightweight and portable, perfect for indoor and outdoor use
• Multiple connectivity options, including Wi-Fi and Bluetooth
• Comes with a projector screen included
• Built-in speaker quality is decent but not ideal for larger spaces
• The fan can be somewhat loud during operation
• Remote control requires direct line of sight for optimal use
• Some connectivity features may vary depending on device compatibility
Overall, I am thoroughly impressed with this projector's performance and value. It offers an excellent combination of quality, ease of use, and versatility, making it an ideal choice for both casual viewers and home theater enthusiasts. Whether for family movie nights, gaming sessions, or even presentations, this projector has proven to be a fantastic addition to my entertainment setup. I highly recommend it to anyone looking for an affordable yet high-performing projector.
Pros:• Portable and compact design
• Excellent brightness and image clarity
• Seamless connectivity via HDMI, WiFi, and Bluetooth
• Easy to set up with electric keystone correction
• Versatile screen size options
• Speakers might not be loud enough without external support
• Some skepticism about achieving true 4K quality
• Can get warm after extended use
Overall, the VISSPL 4K Supported Video Projector has exceeded my expectations in terms of performance and usability. It serves as an invaluable tool for both personal and professional use, making it perfect for educators, artists, and home entertainment enthusiasts alike. While there are minor drawbacks, such as the sound limitations and warmth during prolonged use, the benefits far outweigh these concerns. I wholeheartedly recommend this projector to anyone seeking a reliable and high-quality projection solution.
