Xmint
The Nvidia Shield TV is a refined version of the best Android TV box for years, packed with impressive new AI-based upscaling technology and a novel space-saving design.
The new Nvidia Shield TV comes in two versions: a £149.99 media streamer and a “Pro” alternative for £199 that is aimed more at gaming.
For those unfamiliar with these types of media streaming devices, they in effect add a smart TV experience to older televisions or replace the often terrible or out-of-date smart elements of more modern sets, so that you can use apps such as Amazon Prime Video, BBC iPlayer and Netflix.
Nvidia is arguably the biggest name in graphics, and also makes mobile chips called Tegra, on which these two Android TV boxes are based. The previous Shield was released in 2015 and, unlike many other smart TVs and streaming boxes, is being kept fresh with a steady stream of updates, making it the best, most supported Android TV experience available either baked into a TV or in a set-top box.
The new Shield TV doesn’t mess with the formula. You get one of the most powerful media-streaming boxes available, running the latest version of Android TV and similar long-term software support.
What’s new is the form factor. The standard Shield TV is not a box but a small tube with a power cable and ethernet socket in one end and an HDMI socket and microSD card slot in the other. The idea is you hide this small tube behind your TV in series with the cable without taking up any significant space.
The remote too has been rethought. Instead of being a thin, touch-sensitive remote, the new version has a triangular profile, takes two standard AAA batteries including rechargeables, has a good weight to it and an assortment of buttons that are backlit when the remote is picked up, including dedicated pause and volume buttons.
The shape may seem odd but it’s designed to prevent it slipping down the side or backs of sofas, and it works. A simple, user-friendly design.
The remote communicates with the Shield TV via Bluetooth and has an IR blaster in the end for controlling the volume on your TV, amp or soundbar. It works great.
Specifications
Holding the back button brings up quick access to the settings menu, while the menu button in the top right can be customised to launch particular apps, settings or functions. There’s even a dedicated Netflix button for jumping straight in.
Alongside direct app support, the Shield TV has Chromecast 4K support built in, which means any app that can be cast from your Android or iPhone, tablet or even computer can be sent to your screen wirelessly, which includes BT Sport but not Apple TV.
Apps other than TV and video streaming services are also available, including Android games and Nvidia’s GeForce Now game-streaming service, which has both paid and free tiers of PC games and works surprisingly well. You’ll need a controller for games, and while Nvidia sells one, you can use any Xbox or PlayStation joypad that supports Bluetooth.
Specifications
- Processor: Nvidia Tegra X1+
- RAM: 2 or 3GB
- Storage: 8 or 16GB + microSD card
- Connectivity: wifi ac, Bluetooth 5, gigabit ethernet, HDMI 2.0b (HDCP2.2), 2x USB 3.0 (Pro only)
- Software: Android TV (Android 9 Pie)
- Format support: up to 4K @ 60Hz, Dolby Vision, HDR10, Dolby Atmos, TrueHD and Digital Plus, DTS-X
- Dimensions: 40mm diameter, 165mm length or 98 x 159 x 259.3mm
- Weight: 137g or 250g
