Optoma UHD35x Projector Review: Is It the Right Fit for UHD Gaming Enthusiasts?
Barend Ray
Active member
First Impressions​
The Optoma UHD38 has a solid and slightly weighty build quality that indicates durability. Its design is sleek and modern, fitting nicely into a home theater setup. While the projector is not overly flashy, it has a professional appearance that should complement most decor. However, the remote control leaves something to be desired with its awkward button layout and lack of responsiveness, especially since it requires precise aiming toward the projector.
Optoma UHD35x Projector​
$999​
Gaming​
UHD35x projector, quick start user manual, remote, batteries for remote, power cable​
Highlight
TRUE 4K ULTRA HD: Experience high-quality home cinema feel with 4K Ultra HD with 8.3 million distinct addressable on-screen pixels.Power requirement : 100 - 240V ±10%, AC 50/60Hz. Input current : 3.5A..Operating in 5~40°C , 10% to 85% humidity (non-condensing).
LAG-FREE GAMING: Ultra-fast 240Hz gaming for blur-free visuals and unparalleled smoothness––combined with Enhanced Gaming Mode to produce a 4.2ms response time at 1080p, 16ms at 4K UHD, for the lowest input lag on a 4K projector
HDR & HLG COMPATIBLE: Enjoy brighter whites and deeper black levels for an enhanced viewing experience of images and videos, enabled by HDR10 & HLG technologies
ULTRA-BRIGHT: Enjoy 3,600 lumens of brightness in your home theater room, family room, gaming room – or even outdoors for backyard movie nights
CRISP, COLORFUL PICTURE: UltraDetail technology ensures enhanced image sharpness with a higher frame rate to deliver a crystal clear picture; RGBWRGBW 8 segment color wheel increases the color ratio for richer, vivid and cinematic image
33 Inches - 300 Inches​
4 Feet - 32 Feet​
1000000:1​
3840 x 2160 Pixels​
3840 x 2160​
3600 lumen​
DLP​
Viewing Experience
The viewing experience with the UHD38 is impressive, delivering vibrant colors and sharp 4K imagery that is particularly stunning in dark rooms. The projector performs well even in moderately lit environments, showcasing a significant improvement in brightness compared to older models. While HDR content looks great, some reviewers noted issues with black levels and contrast, indicating that dark scenes might not be as rich as expected. Overall, the projector excels in delivering an immersive viewing experience, especially for movies and gaming.
HDR10​
240 Watts​
50 watts​
USB, HDMI
Hardware Connectivity​
USB​
Gaming Console, Laptop, Smartphone​
Portable​
10.6"L x 12.4"W x 4.6"H​
Setting up the UHD38 was relatively straightforward, especially for those familiar with projector installations. The inclusion of a 4-corner adjustment feature simplifies the process of achieving a perfectly rectangular image, which is especially useful for those who may not have the projector mounted at the ideal height. However, the lack of lens shift and limited zoom capabilities can complicate placement, requiring careful consideration during installation.
User Feedback​
• Bright image quality, even in ambient light.
• Sharp and vibrant 4K picture.
• Easy to set up with 4-corner adjustments.
• Low input lag, making it suitable for gaming.
• Good color reproduction with HDR content.
• Limited zoom capabilities and no lens shift.
• Remote control is not user-friendly.
• Some reports of color distortion and blockiness in scenes.
• Internal speakers are inadequate for a true home theater experience.
The Optoma UHD38 stands out as a strong contender in the budget-friendly 4K projector market, particularly for users looking to enhance their home theater experience without breaking the bank. It provides excellent picture quality and brightness, making it versatile for various lighting conditions. However, potential buyers should weigh the limitations regarding setup flexibility and the need for external audio solutions against their specific requirements. Overall, if you're in the market for an affordable 4K projector, the UHD38 is worth considering despite its shortcomings.
Trollatopoulous
Got this projector to swap out my old one and I'm super happy with it! Super easy to install on the ceiling and the picture looks awesome!
Trollatopoulous
Awesome picture even during the day! (At night, I switch to eco mode so it's not too bright.) The remote kinda sucks, and the sound isn't great (the volume jumps from 0 to 10, and 1 is super loud). No Bluetooth, so I got a Bluetooth transmitter (1Mii B03) to hook it up to my soundbar, and it works perfectly!
Snagged a sweet deal on a refurbished projector and thought I’d give it a go. It looks brand new and works like a charm! Had to tweak a couple of cables since it’s different from my old 142, but I got it sorted. It’s about 14 feet away from my 100" screen, and the video quality is a huge upgrade from my old one. This will probably be my last projector buy!
