Wyatt21
The PROBOX2 Air is another successful TV Box from PROBOX2 team. It has small size and aesthetic appearance. It has a friendly and easy to navigate UI (APEX UI). Supports DLNA, Miracast and Ariplay. TV Box has a very good performance and supports OTA update, which is very handy to use. PROBOX2 Air copes very well with video playback via kodi, supports video playback at 4K. The combination of Air TV Box with PROBOX2 Remote+ is a convenient way for navigation and entertainment. In conjunction with the gamepad you can easily play the famous game available in the Play store. Once again I want to say thanks to PROBOX2 for sending us a PROBOX2 Air with PROBOX2 Remote+ sample. Is it worth buying? YES !. If you need a reliable TV Box to your home entertainment center, which is in daily use will allow easy access to entertainment, stable operation and easy updates this PROBOX2 Air is for you.
Specifications
CPU | Quad Core ARM Cortex-A53 CPU up to 2GHz |
GPU | ARM Mali-G31MP2 |
Memory / Storage | 2GB DDR4 / 16GB eMMC |
Wireless Connectivity | 802.11ac Dual Band WIFI (2.4Ghz / 5.8Ghz), Bluetooth 4.0 |
OS | Android 9.0 Pie |
Video Output | HDMI 2.1 for [email protected], Support HDR, HDMI-CEC, HDCP 1.4/2 Support conversion between Rec.2020 and Rec.709 |
Audio Output | Via HDMI 2.1, optical SPDIF (5.1/7.1/8.1CH) |
Power | DC 5V 2A adapter (CE, FCC, CCC Certified) |
Peripheral Interface | RJ-45 Ethernet Port (100/1000Mbps), USB 3.0 x 1, USB 2.0 x 1, TF Card Reader, IR Sensor (Remote included) |
Supported Video Format | AVS2-P2, VP9 and 10bit H265/H264 video decode, up to 4K 60fps H.264/AVC up to 4K 30fps H.264 MVC, MPEG-4 ASP up to 1080p 60fps Supports HDR10, HLG HDR and Dolby Vision processing |
Supported Audio Format | S/PDIF Audio DAC 8 channels I2S/PDM interface, supports 8 channels Mic array |
Packing Included | PROBOX2 AirBox, Power Adapter, IR Remote, Dual-Band Antenna, HDMI Cable, User Manual |
Dimensions / Weight | 99mm * 107.5mm * 16.3mm / 190g |
