Pros and cons of smart large-screen TV and projector
Gene
First of all, the smart projector can help consumers get rid of the limitation of the size of the TV picture, and improve the picture size as much as possible while ensuring a better picture effect in a specific environment, so as to bring movie-level super large screen enjoyment to consumers. Objectively, at present, smart projector and physical large-screen TV both compete and complement each other. For the market and consumers, they can choose according to their needs. Projector for traditional television, its use in the home life more space saving. Will tell to a lot of people, the size that lives in a space is the main factor that limits them, and had the TV that saves a space so, natural advantage is dye-in-the-wood. Finally, the screen size is adjustable, which is better than the fixed size of a TV with a screen. Because sometimes we need to adjust the size according to the different environment, and the projector can adapt to the different environment very well, which is relatively better.
Of course, smart projectors have their drawbacks. The biggest problem is the brightness problem, with the increase of size of projection, projector picture mean brightness attenuation, inevitably there will be a day to watch will be vague, it is for viewing the ambient light put forward higher request, consumers need to draw the curtains for you as soon as possible to build a dark environment in order to obtain a better visual experience.
At this point, the physical large screen TV because of the size of the fixed, fixed brightness and occupy a certain advantage, can be watched all day.
