Samuel Miller
When you're trying to watch TV and suddenly there's a gray screen that says "no signal". This is a very tricky problem and can be anxiety-provoking. This article will introduce you to the causes of no TV signal.
This is the most common reason for no signal. If there is a problem with the signal source, then no matter what, the TV will not receive the signal. However, it is usually not the TV's problem, but the signal source.
If you have recently replaced the cable, then the reason for no signal may be a damaged cable. Check that both sides of the cable are connected to the correct interface. If there is a loose or damaged cable, it may result in poor signal reception.
The TV signal may be interfered with by other wireless devices. This may be one of the problems that cause no signal on your TV. Make sure your wireless devices are not in use near your TV.
The TV itself may be faulty. For example, the receiver of the TV set is damaged or dislodged, which may also cause the TV to have no signal.
Here to get how to fix TV no signal.
TV signal source failure
Damaged cable
Wireless Signal Interference
TV malfunction
