The smart TV X series launched by Redmi has been well received by many consumers. Now Redmi has launched the Redmi Smart TV X 2022. While pursuing the ultimate cost-effectiveness, the configuration has been fully upgraded. Let's see how this Redmi Smart TV 2022 review goes.
Ultra-Narrow Bezel, Super Large Screen
When people buy a TV, looks are undoubtedly one of the most important aspects. The Redmi Smart TV X 2022 models are available in 55 inches and 65 inches respectively. We are evaluating the 65-inch model. Its all-metal frame is combined with exquisite brushed craftsmanship and a metal base with a balanced structure. The whole is very simple and elegant. And the Redmi Smart TV X 2022 has a screen ratio of up to 97%, allowing the TV to break through the viewing boundary and bring a large field of view.
Among the 65-inch smart TVs in the $400 range, the Redmi Smart TV X 2022 comes with a pair of metal bases, which are more sturdy and in line with the overall style and design of this TV.
The Redmi Smart TV X 2022 is equipped with the HDMI 2.1 standard protocol interface, as a technical standard for ultra-high-quality audio and video transmission, including dynamic HDR, variable refresh rate (VRR), and automatic low-latency mode (ALLM).
Clear Image, Excellent Display
For smart TVs around $400, many people may not have much expectations for picture quality. However, the Redmi Smart TV 2022 has reached the professional display-level color standard of △E≈2, which can restore the color of the picture more realistically. At the same time, it supports up to 1.07 billion color display, and the color rendering is also richer and more natural. In addition, the DCI-P3 color gamut adopted by the Hollywood film industry reaches 94%.
From the actual viewing experience, the Redmi Smart TV X 2022 has a very good performance. In addition to having very good clarity, the color performance is relatively natural, the color reproduction is accurate and rich in layers, bringing a very shocking viewing experience.
In addition, it is worth mentioning that the Redmi Smart TV X 2022 supports Dolby Vision, HDR10+, HDR10 and HLG.
One of the big advantages of the Redmi Smart TV X 2022 is its dual 120Hz high refresh screen. On the one hand, the TV screen is equipped with a 120Hz high refresh screen, which can display up to 120 pictures in 1 second. On the other hand, its 120Hz MEMC motion compensation function makes the moving picture look clearer and smoother, which is better than the effect of playing at the normal frame rate.
After the MEMC motion compensation function is turned on, not only the sharpness of the dynamic picture is greatly improved, but also the smear is reduced, and the overall picture is smoother.
Higher Configuration, Smoother Operation
Redmi Smart TV X 2022 is equipped with MTK 9650 flagship TV chip, using 22nm process, quad-core A73 CPU architecture + Mali G52 MC1GPU architecture + 1T computing power APU. With the support of flagship chips, it achieves a breakthrough upgrade in audio and image quality, while also providing extremely smooth system performance.
The Redmi Smart TV X 2022 has 3G+32GB of memory, which not only makes it run smoothly but also supports downloading various apps. In addition, this TV supports AI dynamic scene recognition, which can intelligently analyze, identify, and adjust the picture. There are also 22 image quality algorithms, including color, sharpness, and contrast, to enhance image expression in all directions.
The sound system of the Redmi Smart TV X 2022 is composed of two dual-channel four-unit speakers with a power of 12.5W, which supports stereo playback.
Summary
The Redmi Smart TV X 2022 provides good performance at a cost-effective price, allowing more average consumers to experience the functions that were only available on high-end TVs in the past, which really achieves the concept of "extreme value for money".
Summary
