The Redmi X43 smart TV has been released in India for Rs 28,999. How's the Redmi X43 review? Let's have a look.
The Redmi Smart TV X43 is equipped with a 43-inch 4K resolution screen, supports Dolby Vision, supports HDR10+, and DCI-P3 92% color gamut coverage. It is equipped with Android TV 10 operating system and is equipped with a 30W speaker that supports Dolby Audio + DTS Virtual: X. Redmi Smart TV X43 adopts HDMI 2.1*3 interface and supports dual-band Wi-Fi and Bluetooth 5.0. And it is equipped with a quad-core A55 processor with 2GB of memory + 16GB of flash memory.
The Redmi Smart TV X43 offers a screen size of 43 inches, which is suitable for those with small rooms. It has two stands at the bottom, and it looks small and cute in appearance. This smart TV has a screen resolution of 3840 x 2160 pixels, so users can get support for 4K HDR and Dolby Vision content on this TV. In addition to this, the Redmi Smart TV X43 also supports HDR10+, HDR 10 and HLG content.
The Redmi Smart TV X43 provides 30W speakers and supports Dolby audio for a rich audio experience. Beyond that, DTS Virtual:X technology enhances audio for an immersive experience in any room. On the software side, the Smart TV X43 runs on the Xiaomi Patchwall UI based on Google's Android TV platform. Smart features include universal search, quick wake-up, kids mode, smart recommendation, user center and live channels, etc.
In terms of hardware capabilities, this Redmi Smart 43-inch TV features a quad-core CPU paired with 2GB of RAM and 16GB of internal storage, which is enough to watch movies and TV shows.
For wireless connectivity, the Redmi Smart TV X43 has Bluetooth 5.0 and dual-band Wi-Fi. As for port options, there are 3 HDMI 2.1 slots (eARC), 2 USB ports, 1 Ethernet, 1 AV port, 1 optical port, and a 3.5mm headphone jack. These rich interfaces provide the possibility to connect other devices.
In addition, the Redmi Smart TV X43 also includes built-in Chromecast, Google Play Store and a Bluetooth remote, which comes with some hotkeys for Google Assistant, Netflix and Amazon Prime. If your budget is not too high, this low-to-medium-priced smart TV is undoubtedly an excellent choice. Have you bought this Redmi Smart TV? How do you review it? Looking forward to your feedback here!
