SAMSUNG CU7000 Smart TV: Is Crystal UHD clarity worth the sacrifice of immersive sound and gaming performance?
ErkkoTheDwarf
The Samsung 43-Inch Class Crystal UHD CU7000 Series Smart TV is being touted for its advanced features, but does it really live up to the hype? With innovations like PurColor technology and Object Tracking Sound Lite, it promises a viewing experience that’s vibrant and immersive. However, in an age where 4K is becoming the standard, can a mid-range model like this truly compete with higher-end options?
As we dive into the specifications, we’ll explore whether the touted benefits—like the Crystal Processor’s capability to upscale content and the HDR's enhanced color spectrum—actually translate into a significant improvement in your day-to-day viewing experience. And let’s not forget the implications of built-in Alexa; convenience or just another point of potential failure?
Join me as we dissect the real-world performance of this TV, weighing its strengths against its limitations, and consider whether this model is the right choice for your home entertainment needs or if you should be looking elsewhere.
Spec​
SAMSUNG CU7000 Smart TV​
SAMSUNGCU7000SmartTV.jpg​
43 Inches​
$410.43​
Model Year​
2023​
Specific Uses​
Home Viewing​
User Manual, E-Manual,Power Cable​
PURCOLOR: See a wider spectrum of colors than traditional RGB models with PurColor; From green turf to an amazing sunset, you’ll enjoy true-to-life picture quality with our innovative color technology
CRYSTAL PROCESSOR W/ 4K UPSCALING: Watch the content you love upgraded to dazzling 4K resolution; You’ll be able to better enjoy your TV’s capabilities as the Crystal Processor automatically transforms color, sound and more
MEGA CONTRAST: See more detail as our Mega Contrast analyzes and adjusts each image; Every frame appears more natural, and a feeling of depth is added as contrast is dialed up in the foreground
HDR: Take in an impressive spectrum of colors and fine details, even in the darkest scenes; Brightness and contrast are automatically dialed into their ideal levels in every frame so you can see your content as it’s meant to be seen
OBJECT TRACKING SOUND LITE: Get in the mix with Object Tracking Sound Lite; You’ll hear 3D surround sound that follows the movement on screen using our incredible virtual top channel audio
Operating System​
Tizen​
Internet Applications​
Apple TV+, Samsung TV Plus, Netflix, YouTube, Prime Video, Disney+, Hulu, Xbox, Nvidia GeForce NOW, ESPN and Max​
Bluetooth​
Aspect Ratio​
16:9​
Display Technology​
LED​
Screen Finish​
Flat​
Resolution​
4K​
Refresh Rate​
60 Hz​
PURCOLOR, Crystal Processor with 4K UHD Upscaling, Motion Xcelerator, Mega Contrast, and HDR​
Motion Enhancement​
Motion Xcelerator​
Audio Channels​
2​
Audio Output​
Surround​
Audio Input​
HDMI, USB​
Speaker Description​
Surround​
H.265 (HEVC)​
Screen Mirroring​
Miracast​
Wi-Fi and Bluetooth enabled devices, HDMI and USB connected devices, and smart devices with Samsung Smart TV Hub​
Tuner Type​
ATSC​
PurColor; Crystal Processor with 4K UHD Upscaling; Motion Xcelerator​
Mount Standard​
200 x 200 mm​
Wireless Technology​
Bluetooth, Wi-Fi​
Usb Ports​
1​
USB2.0 Ports​
1​
Audio Out Ports​
3​
HDMI Ports​
3​
Connector Type​
USB, HDMI​
Signal Format​
digital​
Sharing Direction​
TV to Mobile​
Hardware Interface​
Bluetooth, USB, HDMI​
D x W x H​
7.6"D x 37.9"W x 24.7"H​
Item Weight​
18.3 Pounds​
Setting up the TV was surprisingly straightforward, especially since I already had a Samsung in the house. I appreciated how seamlessly it integrated with my existing setup, allowing me to share settings and apps. However, I did find the initial setup a bit overwhelming, with all the information it required. It felt a bit invasive having to provide personal details just to enjoy my favorite shows. I really just wanted to dive right into watching TV without having to navigate through so many prompts.
The picture quality is where this TV truly shines. I was absolutely blown away by the clarity and vibrancy of the colors. Watching classic movies felt like a brand-new experience; I was struck by how much better they looked compared to my old TV. It's almost as if I could reach out and touch the actors on screen! The large screen size enhances the experience even further, making it feel like I'm right there in the middle of the action.
Audio Experience​
While the sound quality was decent, it's not quite what I expected. I found myself wishing for a bit more volume and richness, especially when watching intense scenes or listening to music. I ended up connecting my soundbar, which significantly improved the audio experience, but I hoped the TV's built-in speakers would suffice on their own.
Other Experience​
Overall, my experience has been a mixed bag. The TV itself has been solid in terms of performance, but the frustration with the interface and extensive setup left me feeling a bit drained. It’s also somewhat annoying to deal with the pre-installed apps that I don’t use, and the remote could definitely use a redesign to make it more user-friendly. I found it challenging to navigate at times, especially with small buttons that crammed too many functions.
The biggest pros for me are the exceptional picture quality and the easy integration with my existing Samsung devices. The color reproduction is fantastic, and the size of the TV really elevates my viewing experience. Additionally, I appreciate the number of ports available for connectivity, which makes it easy to hook up all my gaming and streaming devices.
On the downside, the sound quality could use improvement, and the setup process was a bit of a hassle. The remote control design leaves much to be desired, which can make simple tasks like adjusting the volume more annoying than necessary. I also wish there was more transparency about the features, particularly regarding the smart capabilities that I expected but didn’t fully receive.
Despite some hiccups, I’m ultimately pleased with my purchase. The stunning picture quality and the overall performance of the TV make it a worthwhile investment for my entertainment setup. While there are definitely aspects that could be improved, I feel that the positives outweigh the negatives. I’m excited to continue enjoying my favorite shows and movies on this new screen, and I would recommend it to others, keeping in mind the quirks that come with it.
Hellopi314
So, the delivery went pretty much as planned! The drivers were super nice and even called to make sure we were home. They handled everything with care, which I really appreciated. I set it up right from my phone, and let me tell you, that TV is massive! Just a heads up, it doesn’t come with Alexa, though.
But here’s the fun part: we can play Xbox games straight from the cloud using the controller, which is awesome! The entertainment hub is pretty neat, too. Now, the picture quality is a bit on the darker side, but still decent. One thing I wasn’t too thrilled about is the sound – it’s not as loud as I expected. Overall, though, I’m loving it!
Wow, this TV is massive and just what I was hoping for! Amazon nailed the delivery—everything came in perfect shape, no scratches or anything. I scored it for around $950, which is awesome. Our couch is like 16-18 feet away, so it’s the perfect size for our space. Couldn’t be happier!
My old 32" TV finally kicked the bucket, so I decided to grab a new one. I already have a bigger Samsung, so setting this bad boy up was super easy! It even asked if I wanted to copy over all my settings and apps from the other TV, and I was like, “Heck yes!” Just like that, I was all set! The picture looks awesome, the WiFi is solid for streaming, and the remote is super simple to use. I’m back to being a happy TV binge-watcher!
