If you want a monitor to connect with your computer or play games, you could try the Samsung RU7300 Curved HDR TV. I think it more a large screen panel than a smart TV. Here is my brife review on this curved TV.
Samsung RU7300 Curved HDR TV Specifications:
Model: N55RU7300FXZA
Screen Size: 65", 55"
Resolution and Upscaling: 4K UHD & Upscaling
Refresh Rate: 60Hz
HDMI/USB Ports: 3 / 2 + 1 Component Video
Backlighting: standard
Speaker Type: 2CH
Connectivity Technology: Wireless, USB, Bluetooth, HDMI
Dimensions: 10.30 x 48.70 x 31.20 inches
Weight: 39.90 lbs
Model Year: 2019
Price: $500 for 55-inch
Samsung RU7300 Curved HDR TV Review:
The picture with the curved screen seems to add a clarity and depth that we simply did not have with an HD flat screen TV. The curved display for better viewing at different angles. I like the color accuracy and extra depth brought to the viewing experince on this TV.
The Samsung TV includes a lot of ads and apps that you can't remove or disable, and that's really annoying.
This curved TV does not include a "smart remote" but a standard old school Samsung IR remote.
I can't connect Bluetooth speakers to the television.
The Samsung TV has limited apps and some apps are useless and cannot be removed.
Refresh Rate: 60Hz
Speaker Type: 2CH
Weight: 39.90 lbs
Model Year: 2019
