Xmint
Amazon Echo was first launched in November 2014. According to the statistics of the third-party CIRP, Amazon Echo sales have exceeded 3 million units. Amazon Echo was not listed immediately after launch, and the actual sales time was only about a year. Considering Amazon Echo’s sales duration and product positioning, Amazon Echo’s sales performance is very good.
In fact, the main feature of Amazon Echo is the built-in Amazon voice assistant Alexa. You can use the voice commands to let Alexa of Amazon Echo to play songs for you, answer calls, send and receive text messages, and even check the weather, tell jokes, call Uber, and order pizza . And Amazon Echo can also connect many different smart products or even smart hubs, and then upgrade these smart products to a version that can be controlled by voice. Just call Alexa in Amazon Echo to switch the lighting and adjust the temperature ... is it cool?
The difference between these is that Amazon Echo and Echo Dot are powered and activated by voice at any time. As long as voice commands are issued at any time within a certain range, there will be a response; but Tap is battery-powered and you need to press the button and then issue voice commands Answer; so in this regard Amazon Echo and Echo Dot are more suitable for smart home stewards.
Another difference between Amazon Echo and Amazon Echo Dot is that Echo itself has a built-in audio, but Dot does not. If you use Amazon Echo to play songs, you need to connect an external audio to have a better effect, but there is no problem in daily answering. However, Echo costs $ 180 and Dot costs only $ 50! ! ! The price is less than one-third, if you only want to use its voice assistant to help control the smart home, the price-performance ratio of Dot is really first-class.
