Skyworth S81 Pro Review: 4K/120Hz OLED TV at $1858
Xmint
On July 22, at the Skyworth TV 2020 summer new product launch conference, Skyworth TV launched a new S series product-S81 Pro , which is a step up from S81 in terms of picture quality, sound quality, interaction, configuration and even industrial design. .
In terms of appearance, the S81 Pro adopts a suspended mountain roof design, a mechanical geometric triangular structure, and a suspended full screen design . The stone gray base is inspired by the core color of the 2020 spring and summer. The back panel is made of imported high-brightness brushed sheet material, with an integrated screw-free back.
Aiming at the subtle habit of watching TV at an elevation angle, S81 Pro has designed a healthy elevation angle of 5° for the screen to relieve users’ neck and shoulder pressure when watching TV.
S81 Pro adopts a new generation of 4K 120Hz OLED self-luminous screen , thanks to the 3D LUT film-grade color adjustment algorithm and 20-point white balance adjustment, the color standard value reaches △E 0.98, realizing the real restoration of the broadcast-grade monitor level.
S81 Pro has a built-in 4K AI image quality engine. Features include 120FPS MEMC (lower frame rate up to 120FPS), super sharpness (ie SR, lower resolution up to closer to 4K), Core Colorful (ie ACM, finer colors), AIPQ (artificial intelligence image quality) technology).
The whole process supports 4K 120Hz film source. For input film sources with a frame rate of 60FPS or lower, it can be increased to 120FPS through the MEMC function after decoding , so that the frame rate of the film source is consistent with the 120Hz screen refresh rate. Whether watching an old movie at 24Hz or a new movie at 120Hz, the picture will not jitter.
In addition, thanks to the built-in APU dedicated to image signal processing in the S81 Pro flagship SoC, 1.6TOPS computing power supports diversified AI functions, including face recognition and scene detection, which can fully optimize the picture color saturation, brightness, and sharpness in real time It also improves the image quality through dynamic vector compensation, making the human face softer and natural, the sky bluer, the grass greener, the food fresher, and the building clearer and sharper.
In addition, S81 Pro is Skyworth’s first OBM self-made CSO model, the first self-developed and self-made CSO solution by Skyworth . Thanks to the flexible characteristics of the OLED screen, CSO (Crystal Sound OLED) makes sound through the vibration of the screen itself. Dissemination, so that the source of the picture and sound are exactly the same, and then realize the integration of sound and picture.
81 Pro also has a far-field voice function, supports voiceprint recognition, can identify male/female/children’s voices, and then personalized recommendations, and can recognize Mandarin and 7 common dialects.
Finally, in terms of price, S81 Pro, 55-inch priced at 12,999 yuan (about $1858); 65-inch priced at 19,999 yuan (about $2858) ; pre-sales will be launched simultaneously on all major channels at 18:00 on July 22, and a 10.1-inch Swaiot PANEL mobile smart screen will be given as a gift. .
lamjs
The S81 Pro was great on paper, but the S82 and S9 series have since ironed out the 120Hz flicker that some 2020 units had. Solid buy if you grab one cheap, though.
