This article will show you the solution to Haier TV has no color.
1. Check if the input signal color of your Haier is normal.
2. Open the menu screen, and adjust the Color if the project is back to normal
3. Try a different color system.
4. Then restart your Haier TV.
5. Make a factory reset to see if it is restored.
